Radiator mount support
Hi,
In the final stage putting together the my 1967 Chevy c10 pickup, and have run into a problem. the radiator mount support mount holes are way larger than the bolts, the mounting holes dementions is ( 1" 3/16 diameter) and the mounting bolts is ( 7/16 ) lots of play. I've received the mounting bolt kit for that year. further reviewing shows the 1969 kit has a rubber mount that goes directly into the hole and seat tightly in the hole ( no give while in the hole). Has anybody experienced this problem and if so, how was it remedied ?. |
![]() Join Date: Aug 2020
Re: Radiator mount support
How about a rubber grommet you could slip in there and then slides the bolt through.
Most and good hardware store has them. |
![]() Join Date: Dec 2013
You have to use the earlier core support bushings on the 67's
![]() https://www.classicparts.com/1960-68...yABEgJnZvD_BwE https://www.youtube.com/watch?v=vMAwVrGpWm0
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
laying low
![]() Join Date: Mar 2001
The over sized hole you asked about is for side to side adjustment of the front end sheet metal alignment.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#5 | |
#6 | |
presently looking at that thought, but so far unable to find any strong grommet material. having to consider the bushing being used for the 1969 Chevy mounts. thanks |
The 69-72 rad mount holes are larger and sit lower. The 67- 68 are smaller and sit higher. The top frame pics was a 70 the bottom pic was a 68.
laying low
That is why the cushions are different from 67-68 and 69-72.
