Old 12-24-2020, 04:49 PM   #1
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Question 72 C10 Removing OEM A/C Bracket - Bolts/Washers?
My OEM A/C was replaced with newer components but the OEM A/C bracket is still installed on the intake.
What do I need to know if I want to remove it. I assume the bolts are part of the intake to block?
Do I need shorter ones? I am sure I need washers.
Granted it is not doing any harm, just bugs me its there not doing anything!
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 12-24-2020, 04:54 PM   #2
notsolo
notsolo's Avatar
Re: 72 C10 Removing OEM A/C Bracket - Bolts/Washers?
No real concerns, just remove bolts, replace...regular intake bolts are about 1 1/4" long...Somebody may want original brackets.
notsolo is offline   Reply With Quote
Old 12-24-2020, 05:13 PM   #3
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
I only have that one now my brother was a dope and did not get them from the shop.
Well, got to get some washer for sure, I spy the others having them. Last thing I want to do is have these bolts push into something important ha!
Richard
Old 12-24-2020, 05:39 PM   #4
BigBird05
They could cause a oil leak or a coolant leak if you don't use sealant on them.
BigBird05 is offline   Reply With Quote
Old 12-25-2020, 11:19 AM   #5
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Thanks guys.
Remove two bolts, get proper washers, use sealant!
Richard
Old 12-28-2020, 12:19 PM   #6
MARKDTN
You sure the aftermarket setup doesn't use a brace there? I would want a rear brace.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-28-2020, 12:26 PM   #7
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Nope, was professionally installed. So I can only assume the job was done right.
Richard
