Old 12-18-2003, 01:45 AM   #1
kwmech
front axle FS
Here it is for you guys that want to do a straight axle swap on your newer 4x.. It is a dana 44 high pinion set up just for this conversion. 4.88 gears, open dif., has a 31.5 spring center, has a flat top knuckle with a steering arm on it already, the wheel studs are the late model metrics, warn hubs. Axle has been pro built and has not been installed yet. Axle is complete locking hub to locking hub and has been comletely rebuilt with quality parts. Asking 2k
Old 12-18-2003, 11:40 AM   #2
kwmech
housing core---450.00
gear set spicer-----185.00
iinstall kit all timken----105.00
inner seals----10.00 each
yoke-----35.00
spicer outer shafts new----110.00
spicer u-joints----about 50.0o
heavy duty DOM tie rod assy.-----169.00
2 flat top knuckles machined-----150.00
x-over steer arm----95.00
warn locking hubs, premium---85.00
wheel bearings and seals----50.00
spindles late large bearing spicer----140.00
metric wheel studs--- 12 @ 1.25 each
spicer ball joints ----90.00
rebuilt calipers with brake pads----80.00
used backing plates 80.00
brand new rotors---80.00
drag link heavy duty DOM 159.00
lower mounting u bolt plate brand new ford---50.00
If you aren't smart enough to do the math it comes out to over 2k invested, not including my time if you cannnot handle that stay
off my post.
Old 12-18-2003, 11:18 PM   #3
nu2-72
chevyguybc, very rude pal. Not to mention a violation of the rules.
My Mother would smack me for being that rude. And I am 45.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 12-19-2003, 12:52 AM   #4
1FaastC10
1FaastC10's Avatar
heh, not the first time i've seen it out of this know it all punk. FYI, the high pinion Dana 44 (this one is factory out of a 78-79 Ford BTW) is the hot ticket for an 88-98 SFA swap, which i'm sure you're well aware of as you already know everything there is under the sun to know, right?
1FaastC10 is offline   Reply With Quote
Old 12-19-2003, 01:43 AM   #5
714x4lover
axles
S-M-O-K-I-N !!!!!!!!!!!!!!!!! ICONS SAY IT ALL
714x4lover is offline   Reply With Quote
Old 12-19-2003, 03:46 AM   #6
Scrub
Collector of rusty Items
Scrub's Avatar
OK, What does "31.5 spring center" signify?
What are Flat top Knuckles? (Sounds better than a flat face.)
Ya never learn anything 'les you ask quesions
KW Mech, you got pics... Mebe so you could educate me
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 12-19-2003, 10:01 AM   #7
smokekiki
Mike
smokekiki's Avatar
Here you go scrub check this out http://www.offroaddesign.com/Dana44crossover.htm And the 31.5 is the distance between the center of the spring perches.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 12-19-2003, 11:31 AM   #8
kwmech
Thanks for everyones help.
Old 12-21-2003, 02:14 PM   #9
kwmech
Still for sale
