Old 12-25-2020, 05:20 PM   #1
duke10
Active Member
duke10's Avatar
8 lug wheels/ split rim 1972 Sierra Grande
Picked up a 3/4 ton GMC that has split rims on it.
Will modern Chevy or GMC 8 lug rims fit on my new 72?
What are my options?
I prefer to keep the stock look, 16" Steelies?
Thanks as always for the information.
duke10 is offline   Reply With Quote
Old 12-25-2020, 05:23 PM   #2
duke10
Active Member
duke10's Avatar
Re: 8 lug wheels/ split rim 1972 Sierra Grande
Pictures
Old 12-25-2020, 09:10 PM   #3
Bones72Super
Bones72Super's Avatar
Yes they will, you can even get f*** 7 inch wide 8 lug 16 inch wheels cheap from pre 97 trucks/vans that will accept stock 3/4 ton hub caps.
Nice truck ! Lets see some more pictures please
WTB 71-72 Original paint Medium Red hood
WTB 1972 Very nice original Parchment seat belt set
Bones72Super is offline   Reply With Quote
Old 12-25-2020, 09:18 PM   #4
duke10
Active Member
duke10's Avatar
Thank you.
That is good news
Old 12-25-2020, 09:59 PM   #5
factorystock
factorystock's Avatar
80's GM 16" x 6 1/2 is another possibility.
factorystock is offline   Reply With Quote
Old 12-25-2020, 11:00 PM   #6
57taskforce
All about them K’s
57taskforce's Avatar
These are my go to if you can find them. I’ve got a set of 90’s steel 8 lug wheels on my K20 currently and they work fine but don’t take factory caps and don’t look quite right to a trained eye. Awesome truck you’ve got there!
Tyler
57taskforce is offline   Reply With Quote
Old 12-25-2020, 11:35 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
Nice truck! Stay away from the 16.5" wheels, as your choices are limited. I bought a set of Firestone TransForce tires for my 16.5" wheels, and I'll have to check, but I think they will soon reach their 5 year expected lifetime. I tow a 6000+ pound travel trailer and wouldn't even consider towing with those tires if they are expected to be trouble. Split rims are heavy duty, and a lot of people won't take them on for tire changes. I would, but was really careful, since improper mounting without a cage to contain them can prove fatal. Of course, 40 years ago when I worked as a mechanic, I was immortal. Now, not so much.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 12-26-2020, 12:14 AM   #8
mr48chev
mr48chev's Avatar
Around here 16.5 tires are getting hard to find at tire stores and seriously expensive compared to 16 inch tires.
Local tire stores haven't worked on split rims for years and with at least one tire chain if a worker carries a split rim inside the tire shop it is grounds for being fired on the spot. When I had my split rims pulled off and 16x8 aluminum wheels installed they didn't even set the old tires on the cement, they hand carried them to the back of the truck and tossed them in the back then and there.
My ongoing truck projects:
Old 12-27-2020, 04:14 PM   #9
duke10
Active Member
duke10's Avatar
More pictures for Bones
There are a set of 8 lug tires and wheels from a 2020 2500hd that are for sale locally.
Uncertain whether these will fit.
Thanks for all opinions.
Old 12-27-2020, 04:35 PM   #10
72c20customcamper
72c20customcamper's Avatar
Believe the 2020 rims are metric pattern. I have Ford rims on mine
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 12-27-2020, 04:41 PM   #11
57taskforce
All about them K’s
That’s correct, somewhere in the late 2000’s or the early 2010’s Gm changed the 8 lug pattern to metric in order to be able to increase there weight ratings.
Tyler
Old 12-27-2020, 04:56 PM   #12
duke10
Active Member
duke10's Avatar
So the 2020 rims will not fit???
Old 12-27-2020, 05:21 PM   #13
72c20customcamper
They will not fit
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 12-27-2020, 05:48 PM   #14
duke10
Active Member
duke10's Avatar
So the Ford 16" steelies fit?
Thank you.
Old 12-27-2020, 07:37 PM   #15
dagnabbitt
dagnabbitt's Avatar
Ford 16" do fit, that's what I used on mine.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 12-27-2020, 08:12 PM   #16
72c20customcamper
Basically most 8 lug prior to the metric conversion should work . Mine are for a 96 F250 has the 4 nubs too so the stock hib caps work
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 12-27-2020, 08:21 PM   #17
jocko
jocko's Avatar
Not that it really matters, but just for awareness - the GM wheels are hub-centric, whereas Ford are generally lug-centric. And either will work just fine.
Old 12-29-2020, 12:28 PM   #18
Greg58
Greg58's Avatar
I scored a set of Ford 16x7 rims off of a 2008 E-350 van, and they are not yet metric. Actually got them free!!
The Van was donated to our Fire Dept. for extrication training, and I was in charge of hauling it off.
Greg
________________
1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd.
2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold}
1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400
2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax.
Greg58 is offline   Reply With Quote
Old 12-29-2020, 02:09 PM   #19
NorCalC20LWB
I tried to find a set of used rims but everything I found was in bad shape. For a few more bucks you can get new ones. These are what I ended up getting.
https://www.roadreadywheels.com/prod...teel-wheel-rim
NorCalC20LWB is offline   Reply With Quote
Old 12-29-2020, 03:37 PM   #20
Joesjunk
Joesjunk's Avatar
These are a heck of a deal I think, already powder coated white too
eBay number 363079644326
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 12-29-2020, 05:31 PM   #21
DDassow01
Would those ebay wheels work on a 70 GMC 2500 with drum brakes? The listing shows 16x6.5 where the Ford ones are 16x7. Not sure if it matters or not.
DDassow01 is offline   Reply With Quote
Old 12-29-2020, 09:23 PM   #22
Joesjunk
Joesjunk's Avatar
Yes they will work. GM wheels were only 6.5” wide, but Ford offered them 7” wide. Either will work
Old 12-29-2020, 09:37 PM   #23
BAD1916
Joesjunk, thanks for posting that. Just ordered a set for my suburban.
BAD1916 is online now   Reply With Quote
Old 12-29-2020, 10:13 PM   #24
Joesjunk
Joesjunk's Avatar
Good deal, let us know how they are when you get them.
Old 12-30-2020, 10:31 PM   #25
BAD1916
Will do, I should have them in about a week and I will update.
