12-25-2020, 06:01 PM | #1 |
Help Identifying Pistons - Upgrade Heads or Replace Engine?
The engine in my truck is seriously wimpy, and I'm trying to decide whether it is worth it to replace the heads or if I should just replace the entire engine. It is a two bolt 3970010 block from 1979 with 991 smogger heads. Compression ranges from 170 to 185. It consumes a quart of oil about every 2000 miles. I took some photos of the pistons using a scope. If these are flat top pistons, then I'm leaning toward putting on some 64cc heads. Is that a good idea, or would I be wasting money on this engine? Are these flat top pistons?
12-25-2020, 09:24 PM | #2 |
Re: Help Identifying Pistons
Decent compression
Cam change and better flowing heads will help wake up your 350 Vortec heads could help wake it up With vortec heads you also need vortec intake With good compression I would check your valve seals for leakage A vortec 350 flows better then the old high hp camel hump heads guys pays big bucks for you can if looking scrounge a used set cheap Yes aftermarket heads can flow better they also cost more |
12-26-2020, 08:07 PM | #3 | |
12-26-2020, 09:40 PM | #4 |
Some will say the 906 head don't flow as well as the 062 heads but don't pay that any mind it has been proven false. Are you sure they came off a c1500? The 906 heads are the HD version and came on the 2500. They should have harden valve seat inserts which is good because these heads are prone to cracks around the valve seats. The cracks don't seem to make a difference on a running motor but it's not recommended to reuse heads with the cracks. I have 906 heads on my motor and it runs great.
12-26-2020, 09:46 PM | #5 | |
1gtec19r1we515721 |
02-06-2021, 09:28 PM | #6 |
I finally finished installing Vortec heads and an XE268H cam on my 350 last night. Woke my neighbors up at 8:30 when I started it up for the first time and broke in the cam and lifters for half an hour. This engine has some get up and go now! I am seriously impressed. I hope my bottom end holds up to the abuse. Thank you gmc684x4 for suggesting Vortec heads.
