Old 12-18-2003, 01:47 AM   #1
skokie
skokie's Avatar
Hesitation
I have a hesitation when I hit the gas pedal. Timing is at 10 adv, Hei Ignition, plugs are gapped at 45 and are new. Plug wires are new. I do have a small crack in the passenger side exhaust manifold that is getting replaced with headers com January. An ideas on what it could be?
skokie is offline   Reply With Quote
Old 12-18-2003, 01:50 AM   #2
oldsub86
Accelerator pump in the carb?
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 12-18-2003, 01:53 AM   #3
Rooster's 67
Rooster's 67's Avatar
low float level, accelerator pump, weak coil, weak fuel pump, weak ignition pick up...
what is the type of hesitation and does it make any noise(pops or back fire through carb?)
is it only on hard accel or only on slow accel
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 12-18-2003, 01:56 AM   #4
dinnut
dinnut's Avatar
cat on manifold?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-18-2003, 02:04 AM   #5
skokie
skokie's Avatar
No noise and its a healthy accel. I wouldnt call it a stomp though. And no cat either.
Old 12-18-2003, 02:10 AM   #6
Rooster's 67
accel pump is what it sounds like. what kinda carb?
Old 12-18-2003, 02:14 AM   #7
skokie
skokie's Avatar
Holley 600. 80457-2. I just put a new edelbrock 2101 manifold on it a week ago. I will check the bowls this weekend and see what they are looking like.
Old 12-18-2003, 02:18 AM   #8
Rooster's 67
check the accel pump and you may look and see if you can change the accel pump cams on that carb. may need a different ramp/cam. not a big holly fan but someone else may know.
Old 12-18-2003, 02:29 AM   #9
skokie
skokie's Avatar
I will do that to. Thanks for the help.
Old 12-18-2003, 12:09 PM   #10
tom hand
CCRider
tom hand's Avatar
I not familiar with that Holley number...is it a square bore? If it is are you using edelbrocks plate to put a square bore carb on a speadbore intake? If not you may have a vacuum leak under the carb.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 12-18-2003, 05:52 PM   #11
skokie
skokie's Avatar
Yep its a square bore carb and I do have the plate for it.
Old 12-18-2003, 09:19 PM   #12
EdB
If all the above doesn't work, look for a worn cam lobe.
EdB
EdB is offline   Reply With Quote
