PVC valve breathing
Trying to figure out how it’s fitting on my valve cover.
Need help on the fitting order. When I removed the cover, I heard something dropped inside the cover. When I took the cover up, this parts was laying inside on the top. |
![]() Join Date: Jan 2001
Re: PVC valve breathing
It's broken. I recommend you replace it.
If you decide to reuse it, the order would be housing, spring, weight, bottom cover. You'll need to figure out a way to glue the bottom cover on.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
[QUOTE=truckster;8855155]It's broken. I recommend you replace it.
If you decide to reuse it, the order would be housing, spring, weight, bottom cover. You'll need to figure out a way to glue the bottom cover on. Are you sure it’s broken? Ok. Where can I get new one? |
[quote=Swedchevy67;8855160]Yes, it's definitely broken.. Positive Crankcase Ventilation (PCV) valves aren't normally disassembled for servicing.. Yours is worn out and has fallen apart.. PCV valves are cheap and available where ever automotive parts are sold... Bought locally from O'Reillys, NAPA, etc, they cost $4 - $5.. Bought on the internet the cost could double or triple..
#5 | |
[quote=RustyPile;8855190]
Thanks |
Looks a lot more like a spark arrestor than a pcv to me.
What hose was it attached to? |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
It is a PCV! No doubt in my mind.....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Easy to figure out.
Which valve cover was it on and where on the carb was the hose hooked to? Pics help. |
Swedchevy67 has a '67 with inline 250.
If you have the original '67 Rochester B, there is no manifold Vacuum Port on the carb. The manifold vacuum port for the PCV is in the manifold, on the top of the 3-4 intake runner, behind the carb next to the head. A spark arrester, if used, goes between the valve cover and the air cleaner. The arrestor is between the 2nd and 3rd hose clamps. Forum pictures.
'67 GMC 2500, 292, 4spd, AC |
#12 | |
#13 |
![]() Join Date: Mar 2003
Don't get all confused. It is a PCV valve
