12-28-2020, 10:23 AM | #1 |
Distributor
Did clean my distributor when unfortunately this
little pin fell out. I forgot to take a picture before, so I hope someone out there could send me one. It’s a Delco III0340 30OD |
12-28-2020, 11:00 AM | #2 |
Re: Distributor
sounds like a good reason to upgrade to HEI . I know this is no help
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
12-28-2020, 12:28 PM | #3 |
Re: Distributor
12-28-2020, 01:02 PM | #4 |
Re: Distributor
Here you are.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
12-28-2020, 01:46 PM | #5 |
Re: Distributor
>> unfortunately this little pin fell out. I forgot to take a picture before, so
I hope someone out there could send me one.<< The picture you included is a web image? The wire measures .037" (inch). A short piece of piano wire should be much easier for you to find in Stockholm. It doesn't need to be pre-bent with that little notch. Hook one end, bend it across the pin and hook it on the other catch. The spring keeps the point plate tight against the pin to allow for wear on the pin. The coil spring keeps the point plate pressed down on the nylon pads. Together they keep the point plate stable so that the dwell doesn't wonder. If the pin hole has too much wear, some guys braze the hole closed and redrill. The point distributor is extremely reliable. The points easily last 10,000 miles if adjusted properly, before needing cleaned/adjusted or replaced. I installed a coil-in-cap HEI 30+ years ago, because I was putting a lot of miles on the '67 and the 10k miles was coming up very often. Divorced and the'67 was my only vehicle. I replaced it with a external-coil, '75 inline six HEI in '05 when I added the AC. It gives more room to remove the cap.
'67 GMC 2500, 292, 4spd, AC |
12-28-2020, 02:00 PM | #6 |
Re: Distributor
12-28-2020, 02:08 PM | #7 | |
Post Whore
Re: Distributor
I replaced the HEI in my truck with the basic Pertronix unit and she runs better than ever.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
12-28-2020, 02:19 PM | #8 | |
Re: Distributor
small pin will be attached, I keep it that way. I got the Pertronix system in my Fiat 124 Spider, so that’s an option. Thanks for your thoughts. Appreciate it! |
12-31-2020, 07:18 PM | #9 |
Re: Distributor
Very good and interesting info Richard...especially the '75 6-cyl HEI with the separate coil setup to clear the A/C compressor.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
