![]() Join Date: Oct 2013
Serpentine/Sander AC Compressor Conversion
Hi, AC sanden compressor/ serpentine conversion question. 1986 chevy truck SB, 350HO 330 GMPP engine, converting to serpentine belt system using GM truck take-off. Want to use sanden compressor.
1). What year serpentine take-off set ups accept sanden compression ( can a pan cake serpentine set-up use sanden, e.g. 93). Any better sanden units- upgrades Thanks, |
![]() ![]() Join Date: Jul 2002
Re: Serpentine/Sander AC Compressor Conversion
This is just me, but I have not seen a factory serpentine setup that used or could fit anything other than the pancake style compressor. Aftermarket (or the GM performance one) may do it, but I have not seen one myslef.
They offered pancake style in serp belt and r134 gas setup .
Also you could go 96-00 truck vortec and get the newer 4 bolt top mount a/c comp setup .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
pancake bracket, then an adapter to run a sanden. its pretty easy to adapt yourself with spacers. the 96up ones tend to leak in the center.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
also a 90's jeep wrangler has a sanden compressor. depending on the year you can get it with or without serpentine pulley. pretty cheap on ebay.
| Bookmarks |
