Old 12-29-2020, 03:15 AM   #1
ChevyRacefan
ChevyRacefan's Avatar
Front spindles Center line question.
My Truck is a '71 with disc brakes, 5 lug 2wd.
It is already "seems" low in the front. Still a bunch of space between the fender lip and top of tire, but that might be the function of the 26" tall tires.
But truck looks lower Than I'd think a stock 70's truck would be.
So my question is, a stock front spindle Where is it in relation to the knuckles upper and lower mounting/ball joint.
I am trying to figure out if someone already put drop spindles on it or not and not sure how to tell a stock knuckle from a dropped knuckle/spindle As I don't know what measurement the spindle center to upper ball joint mounting flange would be stock, and/or lower ball joint mounting flange to spindle center .
Thanks.
ChevyRacefan is offline   Reply With Quote
Old 12-29-2020, 09:26 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Front spindles Center line question.
This should help .
Always post pictures ( if possible ) with your questions ,It helps to get good answers .
http://67-72chevytrucks.com/vboard/s...d.php?t=462976
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 12-29-2020, 10:19 AM   #3
ChevyRacefan
Originally Posted by Grumpy old man View Post
This should help .
Thanks, that will help.
Yes photo's are always a help. But vehicle and I are 2000+ miles away from each other ATM.
Old 12-29-2020, 01:47 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Someone may have cut 1 coil off of the front springs. That would drop it about 2" and it would be hard to tell to the casual viewer.
LockDoc
Leon
Old 12-29-2020, 01:53 PM   #5
weq92f
weq92f's Avatar
From Grumpy's post/link...drop spindle on right:
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
