U Joint Size
I put my truck's info into MOOG's U joint kit selector (77 C10, shortbed, m/t), and it said I need one 1310 series U joint and one 1350 series. Does this sound correct? Seems weird to use one small and one large U joint since something is only as strong as its weakest link. Where is the larger 1350 U joint used on these trucks? The trans end or at the differential?
Re: U Joint Size
I believe is on the rearend, my ford 9 inch takes a larger u joint. I sure someone will chime in for a positive response
Re: U Joint Size
according to my u-joint book, both will be a 1310.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
Re: U Joint Size
They're relatively easy to measure. I suggest you get down under the truck with a ruler before deciding what to buy. There's various tables online that show the measurement differences between 1310, 1350, etc.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
| Bookmarks |
