Old 12-18-2003, 04:07 AM   #1
Rooster's 67
Rooster's 67's Avatar
axle swap 5 bolt pattern into 67 12bolt
anyone know if the axles from 71-72 5 bolt pattern will fit/work in the 67-70 12 bolt housings? is the axle splines and length the same?
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 12-18-2003, 04:22 AM   #2
Injected68LS1
Injected68LS1's Avatar
They aren't a direct fit. They are 3/4" wider each. I think the spline count is the same. I know some board members have done this but used some kind of spacer for the extra length. I would do that personally.
I have 5 lug conversion axles for my 68. I got it from ECE. They make axles that are the right width.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 12-18-2003, 04:43 AM   #3
Rooster's 67
what do the ECE axles set ya back,
and I've heard early model 71 used a different width axle housing that matches the width of the 67-70's
not confirmed
Old 12-18-2003, 09:14 AM   #4
SCOTI
SCOTI's Avatar
Rooster, I think that both ECE & Classic Perf Parts both sell 5 lug conversion axles so you might do some comparison shopping. I believe CCP's kit is axles & drums for 3 bills. I bought better axles from Moser & got drums for a 72 @ Autozone.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-18-2003, 11:08 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Rooster, you're close.
It's the 70s that can go either way. There was a running change during production to wider axles.
The later axles will fit in the early housings, but like was said, they are too long by 3/4 inch. What some guys are doing is fabricating a 3/4 inch spacer that goes between the axle housing flange and the brake backing plate. Then bolt the backing plate on with long bolts. This effectively moves the brakes out 3/4 inch to line up with the longer axles.
Old 12-18-2003, 02:47 PM   #6
Rooster's 67
Nah I'll use the correct length stuff.
they were engineered for the load rating with the flange, and wheel contact in a specific place, ya know. and I have been known to haul stuff around.
