Old 12-31-2020, 03:48 PM   #1
Shugalou
Shugalou's Avatar
Wiper switch
Does the wiper switch on a 78 have the function of pushing it in to spray fluid? Mine has a separate button to spray and it looks like it has been added be the previous owner. I have a replacement bezel and there is no hole for the spray on the replacement.
Thanks guys
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 12-31-2020, 07:09 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Wiper switch
Yes they do. Just get the right one for your option and year.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 12-31-2020, 07:42 PM   #3
Shugalou
Shugalou's Avatar
Awesome thanks for the reply. Might have a busted switch that needs replacing.
Thanks again
Old 12-31-2020, 08:00 PM   #4
Dead Parrot
Re: Wiper switch
Might trace out the washer lines and make sure there isn't a PO added washer pump somewhere under the hood. A lot of folks, myself included, have added an aftermarket washer pump after the OEM wiper motor driven pump died. I found a way to use the OEM push to spray washer switch in the existing wiper switch.
Sounds like your PO may have found an alternative solution.
Dead Parrot is offline   Reply With Quote
