Old 12-31-2020, 06:23 PM   #1
Furno68C20
Build sheet remove or keep it?
Found a build sheet under the bench. Looks pretty fragile so wondering if it’s best to just keep it there or is there a good way to get it out. Super cool find.
Here is a few picture.
Furno68C20 is offline   Reply With Quote
Old 12-31-2020, 07:55 PM   #2
pjmoreland
pjmoreland's Avatar
Re: Build sheet remove or keep it?
Is that a Ford seat?
pjmoreland is online now   Reply With Quote
Old 12-31-2020, 08:25 PM   #3
Furno68C20
Looks to be from the build sheet. Didn’t see that. Either way I think I’ll just keep it the way it is. Nice catch.
Old 12-31-2020, 08:31 PM   #4
72c20customcamper
72c20customcamper's Avatar
Burn it ...
Kidding ,it's pretty cool
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 12-31-2020, 09:25 PM   #5
pjmoreland
pjmoreland's Avatar
The seat in my truck was replaced by the previous owner, so I don't have a build sheet. I wish I had one
Old 12-31-2020, 09:43 PM   #6
Gigem
Gigem's Avatar
The one I took out of my 1972 Chevelle SS convertible was in much worse shape than that. I took it out piece by piece, Scotch taped it back together and then had it laminated. Came out great!
1972 GMC Sierra Grande (current truck)
1980 Chevy Stepside (gone)
1987 Chevy Blazer (gone)
1972 Chevelle SS Convertible (gone)
1973 Chevy Corvette (gone)
1967 Chevy Camaro (STOLEN!)
Gigem is offline   Reply With Quote
Old 01-01-2021, 01:53 AM   #7
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
If you can pull it out safely it's now or never. Personally I'd make a copy of it for your truck and store the original away.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-01-2021, 07:50 PM   #8
superchevy
Got big-block?
superchevy's Avatar
the build sheet on my '67 was glued to the fuel tank...no removing it, lol
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 01-02-2021, 02:06 AM   #9
71CHEVYSHORTBED402
Never seen that, perhaps a 67 thing? You can never get rid of that tank now
Tony
Old 01-02-2021, 07:39 AM   #10
Killer Bee
Killer Bee's Avatar
although it's a ford seat, my very well be worth decoding to reunite with the right truck/owner.. if this is a possibility you may entertain to complete someone else's ford project, may be better to just leave it there.. you never know, may be guy out there looking for a genuine seat just like a lot of us are..
before anymore handling, I would take a few high resolution pictures at different angles around the springs for reference in case it crumbles.. might even be worth writing down the data in their respective form fields for your or someone else's research..
if you decide to remove it, a helper may improve your odds of success.. with the gracious assistance from Mr.s Bee, we were able to use four hands to remove both copies from the red longhorn seat, one in the back and one in the bottom.. gently compressing the foam while lifting the springs allowed us to coax the papers out with little damage..
there was even a copy in the glove box but it suffered a lot of loss around the fold areas.. fortunately, I was able to overlay a couple of them to create a complete copy
good luck!
Old 01-02-2021, 01:43 PM   #11
71CHEVYSHORTBED402
Just saying Ford over-engineered their build sheets. Keep it simple, so what do they do instead but build a build sheet like they do a Ford.
Tony
Old 01-02-2021, 04:45 PM   #12
Eric Johnson
Eric Johnson's Avatar
My 67's was carefully taken out photocopied and and then placed back under the seat. It is still in amazing condition. This is the copy.
You could do the same possibly.
1967 GMC 3/4 ton custom. 283 4 speed unrestored
Eric Johnson is offline   Reply With Quote
Old 01-02-2021, 10:47 PM   #13
Furno68C20
good luck!
I’ll get as much info from it as-is. Would be cool to find its owner but how does one begin the search? Can you imagine if someone did that for one of your trucks. That would be a super score!
Old 01-02-2021, 11:10 PM   #14
68bowtie
68bowtie's Avatar
It doesn’t do any good sitting behind the seat. I would take a high-quality photo of it, do your best to get it out carefully, tape the pieces back together and laminate it.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Old 01-03-2021, 12:07 PM   #15
71CHEVYSHORTBED402
Wow, you pull it young or never use the truck My 72 has one behind the seat, it's folded in half. Just a touch it crumbles, I'll likely never read it and it's not worth pulling the seat - knowing the truck I'd probably snap a bolt
This one is off my 71, which was under the seat. Truck was garaged quite a bit. I'm putting the copy back in, something to be said for a good sheet protector. If ever wondered what an original "S" looked like, pretty sure anyway, I found it on the floor with the clip.
Tony
