Old 12-18-2003, 07:21 AM   #1
doughby82
doughby82's Avatar
how to remove steering bearing
i have the steering wheel off,and i can see the bearing,but the turn signal canceller off,i also remove the 3 screws from it,its seem to be stuck on the right side.i think the harard button is holding it up.also is it a special bearing i have to order or can it be bought at a hardware store.
springfield illinois
2003 custom (harley)built from scratch
68 swb
doughby82 is offline   Reply With Quote
Old 12-18-2003, 03:00 PM   #2
Rooster's 67
Rooster's 67's Avatar
pull the hazard switch button, then the signal switcg should pull up, is the bearing bad? you can pick up the bearing from the dealer, and I belive the newer coulum bearings will work in the older coulums. also make sure there is a tapered race for the top of that bearing. if you got a camera post a picture of the parts you have, you may have parts missing if the shaft is loose.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 12-18-2003, 05:08 PM   #3
doughby82
doughby82's Avatar
how does the hazard button come out
68 swb
Old 12-19-2003, 09:47 AM   #4
JimKshortstep4x4
Talking
If it is not a tilt wheel the hazard button does not have to come off. Make sure the button is in and then tip the switch and work it out.
Jim
