Dash Gauge ?
So I popped the dash gauge cluster out 63 C10 to clean up gas gauge was pegged full at all times even with no battery. Anyways I noticed this cluster has a couple extra lights. There is 1 on the left side of colum and 1 on the right,1 reads tandem lock and the other side had a warning ( cant remember now ) thought this might be a transplant from a big truck or were these used in all trucks.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
![]() Join Date: Aug 2008
Re: Dash Gauge ?
Probably Overspeed Warning? Was there actual bulbs and wiring to the sockets?
![]() ![]() ![]() Join Date: Jan 2018
Re: Dash Gauge ?
My guess would be a transplant from a big truck. Both my clusters that came from 1/2 ton truck don't have those
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Re: Dash Gauge ?
No there was no wiring or bulbs just the tubes and little sign to them and yes I belive it was a speed warning
Re: Dash Gauge ?
Good chance it was original to your truck. Just not wired up. Ive pulled them from trucks before that had them but not the wiring. Also have pulled them and the holes were taped over that looked factory. If only theses trucks could talk.
Re: Dash Gauge ?
Ohh OK cool thats whats cool is finding all the cool stuff in these found an old registration from 1984 and a couple of rodeo contestant #'s under the seat.
Re: Dash Gauge ?
Not lucky enough to find the paper build sheet in the seat back? Bought a 61 once and found a .38 revolver in the passenger side inside cab corner pocket. When I contacted the previous owner, he said "I have been looking for that pistol for years".
Re: Dash Gauge ?
Nope not that lucky ,the seat was chaged out a some time for a different bench seat with a custom 4x4 wood block on each side to get heigth. So the guy must of been short.
Re: Dash Gauge ?
There was a thread where someone change the overspeed light to a brake warning or similar. I have thought about doing that.
