Old 12-18-2003, 10:19 AM   #1
Blake_72_Blazer
Question Lights problem
Here is the problem. I start the truck and turn on the lights and everything works, headlights, panels, brakes, and tail lights. Sometimes after a few minutes the dash panel, brake, tail, and sidemarking lights go out. The headlights, turn signals, and flashes still work. If I stop and turn off the truck for a few minutes, everything works again. Then after a minutes the lights go out again.
Any ideas?
Blake
Blake
72 Blazer, 350, tubro 350, NP205, 32x11.5x15
http://home.comcast.net/~blakesara/K5Photos.htm
Blake_72_Blazer is offline   Reply With Quote
Old 12-19-2003, 10:44 AM   #2
JimKshortstep4x4
Talking
I would start by checking the bulkhead connectors. If they are ok, I would check the headlight switch and the orange feed wire from the fuse block.
Jim
Old 12-19-2003, 01:14 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Sounds like something is overheating. The headlight switch on my old Escort GT used to overheat when the fog lights where turned on. All the lights that were wired through the head light switch would turn off until the connector would cool down. Ford was smart enough to put in a switch that couldn't handle the load when the fog lights were on. On top of that, they put the fog light switch flat on the center console. It would inavertently get turned on all the time.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-27-2003, 04:57 PM   #4
Iron-Butt
454 club
Iron-Butt's Avatar
ttt
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
