Old 12-18-2003, 11:06 AM   #1
trinic
trinic's Avatar
will these wheels fit??
Need some help. I have a guy selling some 20" wheels. Width of the wheel
is 10" and the backspacing is 6". He's
not sure about offset, since he has
the wheels on his truck and can not
measure them. My truck has a 2/4 inch
drop. Will these wheels fit nice under my truck?
Forgot to add that he has them installed in a new suburban....
Thx,
trinic is offline   Reply With Quote
Old 12-18-2003, 02:02 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
back spacing and offset are two different ways of saying the same thing. On a 10" wide rim with 6" of backspacing the offset is 1" out which is a positive offset(1"). Negative offset is when the wheels stick out and the same rim above with 1" of negative offset would have 4" of backspacing.
Will they fit? I will have to allow someone else to answer.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-18-2003, 02:09 PM   #3
cdowns
cdowns's Avatar
the easy way to tell is take a jack and some jackstands remove them from the sub and install them on your truck and see how they look , should take about 30minutes
Old 12-18-2003, 02:59 PM   #4
trinic
trinic's Avatar
seems that's about the best way to go
Just wanted to make sure if they'd fit before I made the long trip....
Thx for helping....
Old 12-18-2003, 05:38 PM   #5
gr8scott51
gr8scott51's Avatar
Lots of threads on this subject. Try the search feature. As far as I know, the max back space is 4-1/2".
scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 12-18-2003, 06:06 PM   #6
photoglg
photoglg's Avatar
My Neighbor has a set burb wheels and I tried them on my stepside and they would not fit, the tire hit the bed before the studs were showing. I think 4.5" is the max offset. His were 6"
1969 GMC S/B S/S 3" drop
photoglg is offline   Reply With Quote
Old 12-18-2003, 06:07 PM   #7
trinic
trinic's Avatar
Thx for your help
Guess I'll pass on the wheels....
