Old 01-02-2021, 07:08 PM   #1
JQ-72
JQ-72's Avatar
Brake drum stuck! How?
Working on a 68 1/2 that’s been sitting for a year. Left front drum was tight but it would roll. Topped of master cylinder and went to bleed all 4 corners. Couldn’t get left front to bleed, found that rubber line was stopped up. Replaced line and bled air bubbles out. Test drove it down the driveway and when I applied the brakes the left front locked up and will not release. I took the wheel off and tried to break it loose with a big pry bar and had to stop when I started bending the lug nuts! First, I assume that the wheel cylinder is frozen up? What then? How do I get it loose or get the drum off? Thanks for any help.
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is offline   Reply With Quote
Old 01-02-2021, 08:47 PM   #2
LONGHAIR
Re: Brake drum stuck! How?
Did you have the drum off during the line replacement? Check out, clean, lube, adjust the shoes at that time?
I would open the bleeder to be sure that there is no pressure first. If it is still locked up after that, adjust the shoes inward to get it apart. (that was the point of the first question)
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-02-2021, 11:45 PM   #3
JQ-72
JQ-72's Avatar
I left the shoes on when replacing the line. I did open the bleeder after the wheel locked up and fluid oozed out but it’s still stuck. I’m going to try turning the adjuster tomorrow and see if it will loosen up
