Old 01-03-2021, 04:48 PM   #1
easyrider
easyrider's Avatar
P/s bracket
I have been working with the p/s pump mount for a month now. Started off with no brackets and tried all available brackets that friends said would work, but none would line up and work.
Could any of you guys have the brackets in your pile of extras that i could get to finally complete this project? All help will be greatly appreciated, since i can't move on with restoration until i get past this fix. Thanks in advance for any help you can provide.
easyrider is offline   Reply With Quote
Old 01-03-2021, 05:41 PM   #2
kwmech
Re: P/s bracket
So I take it were working on a 250 or 292?
Old 01-03-2021, 07:05 PM   #3
easyrider
easyrider's Avatar
Re: P/s bracket
No, i'm told that this won't work either. You are right; for wrong engine!!
I'm putting a power steering pump on a 1984 305 and i have no idea what brackets go with this set up. It came to me in boxes. I am open to any teaching and instructions that make this work. If you have one that is together and working please send anything that will explain what brackets I will need. PHOTOS OF BRACKETS WOULD BE GREAT!
I don't claim to be a genius but this thing is whipping my butt and making me feel really stupid.
They say it's the simple things that cause the most problems. Should be easy, but just can't get a handle on how this all goes together. Thanks for the help....
Old 01-03-2021, 07:55 PM   #4
rechinca
rechinca's Avatar
Re: P/s bracket
Well the first thing we will need to know is are you keeping the with the king water pump or short water pump? And are you wanting any PS that will work, factory style, correct style pump or any other variations. Post up a pic of your engine so we can start seeing what you have and guys can give you a better idea of what you need parts-wise. I went through absolute craziness trying to get the correct pullies and pump to go back with the OEM style set-up.
1971 Custom/10 - 350/3 speed, Orange/White roof
rechinca is offline   Reply With Quote
Old 01-03-2021, 08:16 PM   #5
Andy4639
Old member
Andy4639's Avatar
Question Re: P/s bracket
Yea we really need to know what water pump you have on the motor and crank pulley. Do you want to stay stock are you willing to go with aftermarket?
Your 305 should be the basic setup as a 307. Do your heads have the bolt holes in them on the front side of the heads and block to mount the brackets?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
