American Powertrain Hydramax clutch question
I was wondering if anyone here had used an American Powertrain Hydramax clutch master cylinder kit on a their 67-72 pickup. I recently purchased a whole setup flywheel to driveshaft Magnum t56 with the Hydramax kit included. I have every piece of paperwork that came with it new. I cannot find any pics or videos related to where to mount the master cylinder on the firewall of my 67. Any help is appreciated. Thanks
![]() Join Date: Nov 2008
Re: American Powertrain Hydramax clutch question
I would just call them. You’re paying the dough for service so they should help you out. I just bought a complete kit from SST for my Monte Carlo (same deal, distributor for tremec). They have helped me with tech questions.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
Not Hydramax but the pic shows the general location of the master I got from Captain Fab.
Yes. I installed a complete Hydramax clutch kit this past winter. You have to install the linkage to the pedal in order to determine the location. Mine ended up between the engine valve cover and the master cylinder but I ran an after market set of pedals. Make sure you follow the instructions because if you end up with the wrong angle the clutch pedal linkage will bind up when you press the pedal. When its done, the master cylinder for the clutch will be on an angle. Mine was a pain in the A** but it turned out nice and is really nice to drive as opposed that old mechanical hard to push system. American Power train kit is top notch.
I have the same kit purchased from Captain Fab. I wasn't sure it would work with the Hydramax slave. I plan on using the American Powertrain pieces since I have the whole kit, slave cylinder and all. The Captain Fab stuff is top notch, the Captain needs to school American Powertrain on their instructions.
Tags |
american powertrain, hydramax |
