1970 K10 Cardan Front Driveshaft
Hey I'm rebuilding the front driveshaft on my 70 Suburban and looking for replacement U Joints. Has anyone done this and can tell me if all 3 U joints are the same? Looking at both Rockauto and Advance Autoparts and can't tell them apart.
Thanks Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
All about them K’s
![]() Join Date: Jun 2014
Re: 1970 K10 Cardan Front Driveshaft
They should all be the same, Denny’s driveshaft can set you up with everything including the centering yoke for the upper cv shaft.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
![]() Join Date: Feb 2000
Northern Drivetrain should have everything you need too- they're a Spicer and Neapco supplier
https://www.northerndrivetrain.com/c...shaftcomp.html
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
![]() Join Date: Mar 2003
They should all be a 1310 u-joint and check the pivot shaft and ball assy closely for wear
Thanks guys I was able to order the Moog universals and the pivot shaft.
Next question and hopefully I can explain it. On the front slip yoke there is a cap that holds the grease in the splines. When you remove the yoke you have to unscrew the cap. Inside of the cap is a seal of some sort. What is the seal called? Thanks Paul
#6 | |
