Old 01-05-2021, 09:37 AM   #1
kaycee
kaycee's Avatar
Fuse box
63 C10 only about half of fuses box has power .I have tail lights,blinkers front and back. I just pulled this ruck home so still trying to figure out what is what and what was cobbled together. Key on I only have about 3 fuses hot pulled fuses to make sure they are good contact and looks like no wires are butchered up or spliced. So my ? is reading the schematic from FAQ forum the hot comes in through the light switch and then to the fuse box.I lose power at the firewall and no power at rad. support.I'm thinking the light switch is the culprit any ideas ?
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 01-05-2021, 10:57 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Fuse box
Pretty good wiring diagrams on this page beginning thread 12. http://67-72chevytrucks.com/vboard/s...d.php?t=378484
Old 01-05-2021, 12:52 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
Re: Fuse box
I lost power to my headlight circuit when the power wire on the back of that circuit had corroded. I had to crimp on a new connecter and everything worked again. I also thought it was the headlight switch, so I replaced it, but that still wasn't the issue. I found the corroded wire after the switch replacement
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-08-2021, 09:32 PM   #4
kaycee
kaycee's Avatar
Re: Fuse box
Ok changed out the floor dimmer switch and got my headlights new and the fuse panel is working as it should.So went over to the heater have no fan notice on the wire schematic that it doesn't show the fan switch wiring.
2005 FXDWG stage3
63 IMPALA 327/4L60
