![]() Join Date: Jul 2015
Suspension, carbs, and BBC push rods
I've started to go though my stockpile of stuff and have decided it's time to down size some things. Some items are cross posted, all are first come first served, will ship at buyers expense, items are in Northern VA, I travel to the Richmond and Williamsburg area often too.
I have two Holley carbs that were on my 427sbc in my Camaro; First Carb is a 750CFM, still has choke horn but no choke components. Was on my car last season and ran great, pulled off this year to change up to the 850. Drained all the gas out before storage, has been off the car since May. List # is 4779-6, has brown accelerator pump cams on it, 4 corner idle, rear power valve is blocked off. $250 OBO Second carb is an 850CFM double pumper, was removed to go Sniper FI the week of Christmas, choke horn has been milled off, I have pictures of it prior with all the numbers, it is a list 4781-5. Has 81's front and rear, front power valve is a 3.5 and the rear is blocked off, dual 50cc accelerator pumps, also a 4-corner idle carb. $300obo Set of COMP 3/8" BBC push rods, 9.250" part #7141-16 $60obo Stock upper control arms off my 71, need blasted and rebuilt $60 obo Fleet side wheel tubs off my 71. Most of the tub is good, the flanges in areas are rotten. $50 obo for the pair Set of great shape rear trailing arms. No rust, bends, cuts etc, both spring retainers included, will get them un bolted. $250 obo
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
Re: Suspension, carbs, and BBC push rods
more pictures
pictures round 3
Bumpity bump
Bump it up!
| Bookmarks |
