Old 01-07-2021, 01:52 AM   #1
Marksurfer
69 Chevy C20 Steering Question
I've read some different past threads trying to figure out my issue. Just finished up a restoration or my restoration guy did on 69 C20. i didn't not change out or make any mods, just all new steering components (tie rods, ball joints, etc.) Also upgraded to a new quick ratio steering box. Had a full alignment done also. It drives nice and straight, but seems finicky. It seems to pull quickly with to L or R with slightest movement. doesn't have the smooth rack/pinion feel. it has the original steering wheel and shaft, but everything else is new.
Any ideas or suggestions?
Marksurfer is offline   Reply With Quote
Old 01-07-2021, 03:23 PM   #2
bry593
Re: 69 Chevy C20 Steering Question
What ratio is your steering box? A 10:1 ratio with the large diameter steering wheel, will feel a bit darty. You'll get used to it. I think trucks work best if you keep the quick ratio closer to 14:1.
Nice truck by the way!
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
Old 01-08-2021, 01:35 PM   #3
68 P.O.S.
Is your centerlink backwards? Upper A-arms on the correct sides? Need more pics
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 01-17-2021, 12:06 AM   #4
Marksurfer
Wink Re: 69 Chevy C20 Steering Question
Sorry for the late reply back.. Not sure on which ratio of gear box he installed, i just went from the standard gear box to a new quick ratio, which i believe is 3 1/4 turn vs the stock 4 1/2 turn lock to lock. Figured out the issue though. He said he would get it aligned after he installed the new gear box and apparently it wasn't. Got it aligned and now drives much better. It definitely is more responsive and turns much better. With the original big steering wheel is very sensitive or can be darty like you mentioned. Not my everyday driver so good enough for me.
Would a steering stabilizer kit help or stiffen up the steering any? I see them listed in the LMC and other catalogs for about $50.
Old 01-17-2021, 08:48 AM   #5
Bigdav160
Bigdav160's Avatar
This! I don't think the box change makes that big a difference
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-19-2021, 12:51 PM   #6
68 P.O.S.
I added one to my 72. Yes, it will help a little, nothing dramatic. The only real differences I've noticed are a small resistance in turning the wheel, and the wheel doesn't return to center as easily or quickly.
Old 01-19-2021, 04:49 PM   #7
Oldironside
Oldironside's Avatar
Had the same issue, also have the same steering box. Tried it with a steering stabilizer but then the steering felt a little bit too stiff. The only thing that did the trick was switching the valve of the steering pump to one with a different diameter (can't say what diameter because it's been quite a while when I did it) to reduce the pressure that goes to the steering box. Now the steering has the right feel.
Oldironside is offline   Reply With Quote
Old 05-26-2021, 04:44 PM   #8
72 paul
Any pics of install of damper out there? 71 C20 2wd.Got a Monroe sa1932.Says it will fit?Thanks for any response.
72 paul is offline   Reply With Quote
Old 05-26-2021, 04:49 PM   #9
54blackhornet
54blackhornet's Avatar
Don’t complain, every drive one without power steering ? Almost dangerous on uneven ground l
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 05-26-2021, 04:58 PM   #10
68 P.O.S.
You ain't lying
Old 05-27-2021, 10:54 AM   #11
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Was your truck a Manual Steering truck before?
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 05-27-2021, 07:53 PM   #12
72 paul
My truck is power steering,real easy to steer and darty.I do have giant tires on front.The damper has very poor install instructions and is, I'm sure universal.Lmc sells same deal in there catalog.Gonna look into slowin down flow in pump too.
Old 05-28-2021, 01:28 AM   #13
lil hoodlum
lil hoodlum's Avatar
I also second this. It is very easy to install the center link backwards and the symptoms are the steering is very darty, or seems very easy to over-correct. Make sure the inner tie rod is installed through the back side of the center link, castle nut is facing forward and grease fitting is on the back side of the center link on the crossmember side.
lil hoodlum is offline   Reply With Quote
