01-07-2021, 01:41 PM | #1 |
AAW Kit Instrument panel question-diagram doesnt match-I have more lamp ports
What have you guys done here who have bought the American Auto Wire Classic Update kit and found that the instructions dont work for your cluster? I have a tach and a vacuum gauge and the holes that you can see in my pic I assume should have lamps in them. I also assume that they need to have lamps to better illuminate the tach and vacuum? One on top and one below to light it up right?
01-07-2021, 01:46 PM | #2 |
Re: AAW Kit Instrument panel question-diagram doesnt match-I have more lamp ports
I would take sockets from your old cluster harness and wire them in. The 2 holes on the bottom are probably for the optional warning indicators typically used on the bigger trucks
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
01-07-2021, 02:17 PM | #3 |
I had wondered what the lower ones were for, when I shine a flashlight into the lower holes there the bottom of the vac and tach get some illumination from below. The tach up top I actually didnt see alot of light glowing on the top of the tach. I guess the bulb needs to protrude more into that upper port so it glows better. At first I thought I mat have done something wrong on the tach install.
01-07-2021, 03:27 PM | #4 |
Exactly what Christian said....the two on the bottom are for overspeed and tandem lock I did not wire those into mine and everything that should works. If you need one over your vacuum gauge, just splice a new bulb into the top of that backing plate. I may take out the overspeed plastic piece and make a new one and make it a brake warning light or something similar.
01-07-2021, 06:32 PM | #5 |
I used one for check engine and the other one for cruise control There kit does not come with the two lights for the tack and vacuum they will sell them to you separately or as someone else said Rob a couple from your old harness
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
01-07-2021, 08:42 PM | #6 |
I added the 3 additional from the old harness. I have some LED bulbs on the way. So until they get here Ill try and tidy this spaghetti up.
