Old 01-08-2021, 02:38 AM   #1
chev-obsession
chev-obsession's Avatar
Motorhome steering box interchangeable?
So yesterday I found a motorhome with a tilt column. While grabbing the column I noticed hydro boost and a familiar looking steering box... the steering box looked identical to the Saginaw boxes on the 10-30 series trucks, however it was mounted at a more vertical angle than the 10-30 series trucks. The motor home said it had 27,000 miles and I believe it, it also looked to be a mid-late 80’s vintage. I’d like to grab it since it’s likely to be a quicker ratio.
Wanting to know if those steering boxes are interchangeable with the c10-30 series frames or if they differ in some way?
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 01-08-2021, 08:26 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Motorhome steering box interchangeable?
A motorhome...
Old 01-08-2021, 09:39 AM   #3
nsb29
nsb29's Avatar
Why not they’re trucks aren’t they? probably the best way to figure it out is to find out what chassis the motorhome was on I have had a couple of motorhomes and I have seen them lined up at the motorhome manufacturers as they come from the dealer class A steering column instrument panel wiring harness all goes to whatever the truck was just no body Or if it’s a class C which is the front cab of a van that would be the easiest to figure out
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 01-08-2021, 11:26 AM   #4
chev-obsession
I’m not sure what all the class’s mean... but it looked like a 1 ton Chevy frame. It was like an “allergo” brand motorhome and not the conversion van style. Just wanting to know if there’s any interchangeability on the boxes.
1965 c/10 swb
1969 c/10 lwb
Old 01-08-2021, 12:02 PM   #5
Wrenchbender Ret
The upper input shaft is different on the P series trucks which that probably is. The fittings for the hose hookup are different on the newer ones then the older ones.
The rest will interchange but I dought if the ratio is quicker.
George
Wrenchbender Ret is offline   Reply With Quote
Old 01-08-2021, 12:07 PM   #6
The Rocknrod
Moderator
The reason I said "A Motorhome" is, what motorhome? What make, Model etc. The options are pretty varied in the parts department. You might have seen one thing and someone else is thinking another because there was nothing identified. Just trying to help get you in the right direction.
Old 01-08-2021, 01:28 PM   #7
chev-obsession
George
Precisely the info I was looking for. Thank you
1965 c/10 swb
1969 c/10 lwb
Old 01-08-2021, 11:15 PM   #8
Captainfab
60-66 Nut
Some of those turn the opposite direction that a C/K steering box does. If the steering box is mounted somewhat vertical with the pitman arm towards the rear, pointing down, it will turn the opposite of what you need.
