01-08-2021, 11:02 PM | #1 |
Dash lights
I'm having trouble with my dash lights going out,sand melting switch. Tail lights still work. New harness ,led dash lights ,has happened twice now.68 c10 panel. Mcbchev
01-08-2021, 11:47 PM | #2 |
Re: Dash lights
More information, pictures, fuse box and fuses in it, etc.
01-09-2021, 10:58 AM | #3 |
Re: Dash lights
I have seen that problem caused by the bulk head connector. Check the connection under the hood.
01-09-2021, 11:09 AM | #4 |
Re: Dash lights
01-09-2021, 11:11 AM | #5 |
Re: Dash lights
01-09-2021, 01:12 PM | #6 |
Msgt USAF Ret
Re: Dash lights
Check the electrical forum in my FAQS thread for info on the dash lights. There may be something there to help you.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-09-2021, 01:18 PM | #7 | |
The Older Generation
Re: Dash lights
http://67-72chevytrucks.com/vboard/s...d.php?t=815300 LockDoc
01-09-2021, 02:28 PM | #8 |
Re: Dash lights
I would guess its dirty connections including grounds all through your lighting circuit. Also if you are running halogen bulbs this will add a lot of heat to your switch. I went with headlight relays and this helped a lot.
01-09-2021, 02:30 PM | #9 |
Re: Dash lights
LockDoc lots of great info on your link thanks.
01-09-2021, 03:16 PM | #10 |
Re: Dash lights
You can thank "VetteVet", he is the one that put it together. Posting the link here was the easy part.... LockDoc
01-09-2021, 03:36 PM | #11 |
Old member
Re: Dash lights
Rats chewing on stuff.
01-10-2021, 02:52 PM | #12 | |
Msgt USAF Ret
Re: Dash lights
And thank you Doc for helping to get the word out.
