Old 01-09-2021, 09:11 PM   #1
Brim
Brim's Avatar
64-66 Instrument Cluster Harness
Anyone replace their panel harness? I just came in from trying to install some LED bulbs and it turns out I am missing like 3 or 4 wires that would have a connector on the end for a bulb. They aren't tucked away anywhere either. They just aren't there. No wonder my panel has always been a little dull at night.
So after replacing the bulbs that were there, my Tachometer gauge and temp gauge lights will not turn on anymore and they used too. Probably loosened a wire or connection when I had my hands under the dash? Anyway I will get that figured out, I ended up just switching the led bulbs back out and putting the regular bulbs back in.
So it looks like I am going to have to order a new dash harness. They run about $70 bucks and then try and swap it out for the new one. Something has always been wrong to begin with my wiring because when activating my turn signals the correct direction always worked up front but both rear brake lights have always blinked at the same time like if I had my hazards on but I never got around to fixing it.
Went the route of adding extra grounds to the tail light bezels and ran a ground wire from the battery all the way back to the end of the frame but still did not fix the issue. Someone had connected a trailer hitch harness on the end but I ended up removing it along with the hitch itself.
By the way I found a light socket that says when illuminated "Over Speed". I never knew the cluster had one. Found it by mistake when I put the turn signal socket/wire in the wrong cluster hole. So back to the harness does anyone know which one is a direct replacement for a cluster with factory gauges? My truck is a 1964 Fleetside. I have looked a few up online but they seem to have a different amount of wires with bulbs?
This one looks like it's for 11 bulbs?
https://www.tuckersparts.com/Dash-Cl...-WIC-6400.html
Classic Industries part runs about $70
https://www.classicindustries.com/pr...hoCPl8QAvD_BwE
And around the same cost from Chevy C10 Parts.com It has around 7 bulbs on this harness...
http://chevyc10parts.com/4685.html
LMC description is confusing, I have attached it. Thanks in advance guys.
-Mark
Brim is offline   Reply With Quote
Old 01-09-2021, 09:14 PM   #2
Brim
Brim's Avatar
Re: 64-66 Instrument Cluster Harness
Also thought I would add a shot of my cluster...
Old 01-09-2021, 09:18 PM   #3
Brim
Brim's Avatar
Better view...
Old 01-09-2021, 11:37 PM   #4
DPowers
DPowers's Avatar
https://67-72chevytrucks.com/vboard/...d.php?t=816610
Roll the dice had some.
DPowers is offline   Reply With Quote
Old 01-10-2021, 12:27 AM   #5
Railroadman
Railroadman's Avatar
It may be a PITA but on trucks this age, new wiring is a wise move. Yes, I know there are many out there with the original wires still fine. But insulation deteriorates, copper oxidizes, wires get worn and nicked, and eventually you have grounds and even a fire. Especially since you have been having problems, IMHO you are smart to go the new harness route.
Railroadman is offline   Reply With Quote
Old 01-10-2021, 12:54 AM   #6
cwcarpenter98
cwcarpenter98's Avatar
It's possible that your original cluster was a standard cluster with warning lights which was swapped out for one with gauges. If the wiring harness wasn't changed along with the cluster, that could be the explanation for your missing wires
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-10-2021, 06:28 PM   #7
Brim
Brim's Avatar
Yes sir, that's what I figured would be best.
Old 01-10-2021, 06:29 PM   #8
Brim
Brim's Avatar
Thanks I didn't think of that. Have you ever seen a cluster with the "Over Speed" light?
Old 01-10-2021, 06:31 PM   #9
Brim
Brim's Avatar
Originally Posted by DPowers View Post
Thanks for the heads up
Old 01-10-2021, 08:13 PM   #10
PGSigns
PGSigns's Avatar
They all had that and the tandom lock socket. The same cluster was used in all the trucks up to the C60. You will have holes that don't get bulbs. If you put led bulbs in what you have you will be surprised on much better the cluster will look. I don't think you are missing 4 light sockets.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-10-2021, 10:16 PM   #11
cwcarpenter98
I've only seen it in pictures on the forum. I've only had the cluster out of my 63 which is a different cluster
Christian Carpenter
Old 01-11-2021, 02:18 AM   #12
Brim
Brim's Avatar
Jimmy
Yes sir, I think it would make a huge difference. I might try buying a different type of LED bulb to see if they work better. The ones I have fit but were deep in the socket housing so they might be a tad small...
