Old 01-10-2021, 11:08 AM   #1
skidoo
72 c10 exhaust
Just bought this truck and it has the exhaust coming out in front of the rear tires. I was thinking of changing it and putting it behind the rear tires on a 45 degree angle. The truck does have the factory overload leaf spring. What are your thoughts leave it or change it?
skidoo is offline   Reply With Quote
Old 01-10-2021, 11:39 AM   #2
Boog
laying low
Boog's Avatar
Re: 72 c10 exhaust
Personal preference really. I had behind @ 45* exits but changed to in front of wheels. I may change some day to a straight out the back setup. Try it and see. And welcome to the forums.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-10-2021, 01:46 PM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: 72 c10 exhaust
I prefer out the side behind the rear wheels. It helps prevent droning in the cab.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 01-10-2021, 07:22 PM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: 72 c10 exhaust
I prefer out the back at each corner like a factory would be. You can barely see it in the last picture.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-11-2021, 07:01 PM   #5
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: 72 c10 exhaust
Mine are out behind my tires. I wanted them further back but they couldn't as I have the auxiliary rear overload spring too.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-12-2021, 09:45 AM   #6
sick472
sick472's Avatar
Re: 72 c10 exhaust
Exhaust looks good coming out of any of the normal places, but different locations certainly change the sound. As far as in front or behind the rear wheel...In front will cause more dusting of the wheels especially if you travel any gravel roads. Behind cuts that down alot, but still dusts the bed side and bumper. Behind will reduce exhaust noise some, but probably not very noticable.
When duals exit on the sides (without the H or X pipe), the sound, as you walk around the truck, has more has more of a lope to it because you mostly hear that side of a V8's cylinders. This adds more of a race engine sound, but also adds to the cab sound levels.
My preference is straight out the back, but I'm getting older and peace is more important than lope.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 01-12-2021, 11:25 AM   #7
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: 72 c10 exhaust
Behind the rear tire requires more pipe bent to clear the axle...Its your preference and your wallet...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-12-2021, 12:03 PM   #8
pjmoreland
pjmoreland's Avatar
Re: 72 c10 exhaust
My exhaust exits in front of the rear wheels. That puts the mufflers underneath the cab, which warms up the cab floor. The extra heat in the cab is nice in the winter but not so nice in the summer. I plan to have the mufflers moved to under the bed.
pjmoreland is offline   Reply With Quote
