![]() Join Date: Nov 2001
Lower radiator size
Looking for the correct size lower radiator hose for a
67 C10 PS V8 327. My original four core radiator is out of a 72 C10 Suburban V8 350 with A/C and PS, not sure if that makes a difference. Thanks for any help. NGN Nick |
Re: Lower radiator hose
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Lower radiator size
Is there more to the situation than what is readily apparent ? What difficulties are you having finding a hose ?
A 72 Suburban with 350 takes a Gates 20694. Assuming you're using the typical short water pump and your engine is in the front mount holes, with the 72 radiator, I'd choose the 20694 hose.
Thanks for you help Tx Firefighter. Yes it's a short water pump and the motor sits up front in the V8 position. The numbers on the
Gates hose I got was 20543 (National Auto Parts) may be to years ago, their closed down now. It would twisted and kink no way to make it fit nice. I'll take the ride to Nappa on my way home. Thank you again. NGN Nick |
