Old 01-11-2021, 04:53 PM   #1
msg
66 speedometer cable routing and grommet install
From the kit I have of firewall grommets that aren't identified I am pretty sure this is the speedometer grommet. I assume you cut a slit in it and separate the grommet and slide the cable through and pop the grommet into the hole in the floor? Its been a while since I took this apart and this is one of the things I didn't photograph the removal of. I think the clip on the outside of the firewall will hold the cable once I have it installed?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 01-11-2021, 06:16 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 66 speedometer cable routing and grommet install
That's what I did.
Old 01-12-2021, 10:11 AM   #3
msg
Thanks Rocknrod, I made the cut added some silicone and slid the cable and grommet in place. Is the clip on the outside firewall meant for the speedometer cable?
Old 01-12-2021, 11:59 AM   #4
The Rocknrod
Moderator
The clip?
Old 01-12-2021, 01:28 PM   #5
msg
that little j looking clip thats attached to the outside firewall, under the other hole to the left of the speedometer plug. It may be for electrical wires?
Old 01-12-2021, 01:29 PM   #6
The Rocknrod
Moderator
That's not for the Speedo Cable.
Old 01-12-2021, 02:12 PM   #7
Riverstory
Riverstory's Avatar
That clip is for your brake/parking/backup light cabling that run to the back
Riverstory is offline   Reply With Quote
Old 01-12-2021, 03:02 PM   #8
msg
Thank you both!
