Old 01-11-2021, 07:27 PM   #1
69Tom
69Tom's Avatar
installing springs in truck w/o motor
OK, so I've run a bunch of searches on this subject.
As my truck (70 C10) is blocking my garage and I need to get things in and out of it, I really need to make it roll more easily, so I want to install the front wheels which require me somehow getting the springs installed. I don't have the engine in.
It seems spring compressors are pretty dangerous/don't work all that well depending on what you get. And, based on my studying the front end, it also seems like an internal compressor may be somewhat difficult to get out depending on design.
With that said, my next plan of action was trying to load up the front end. I'd install the engine, but it's completely apart. Would putting the block and the heads down on the front end give enough weight or still not enough? How about block, heads, a person standing on it? haha. It's a 402.
In any event, open to suggestions.
69Tom is offline   Reply With Quote
Old 01-11-2021, 08:05 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: installing springs in truck w/o motor
I recently did a 402, factory height coil springs with a 2.5" drop spindles made it that more difficult. All I can say is with the drivetrain on and a 200+ lb. son sitting on the block we still managed to witness the RH frame rail lift off the rear jack stand (yikes). I agree, I tried compressors and wasn't comfortable using them at all, plus they'll scratch up the coils.
I know, not so encouraging. Perhaps you can do this with sand bags? The more the merrier. They're free 5 minutes from me, may be they're local where you are.
However you do best secure the coils to the A-arm or something during install.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-11-2021, 09:23 PM   #3
Redneck Rydes
Redneck Rydes's Avatar
Instead of putting in the springs if you are not ready for them,just make some jack bolts out of threaded rod,or grab some heavy steal stock and bolt them to the shock bolts after you jack it up,that way you can move it around
Redneck Rydes is offline   Reply With Quote
Old 01-11-2021, 11:34 PM   #4
LS short box
As said above get a length of 5/8" threaded rod. Long enough to run from the lower a-arm to the top mount running inside the spring. Piece of plate steel on either end. Add a piece of chain around the frame to hold the spring in place if it tries to get away from you. Tighten the threaded rod until you can bolt in the ball joints. I typically weld nut to one end of the treaded rod.
LS short box is offline   Reply With Quote
Old 01-11-2021, 11:47 PM   #5
Boog
laying low
Boog's Avatar
You're not driving it with no engine. So...You have firewood? Slide a stick in there across the lower control arm or stack some 2x4s in there and bolt up the spindle. It'll be good enough to roll around on. The big weight is the engine and tranny. I've even seen rigs someone has shoved a chunk of wood in there with a broken spring and just drove it like that forever.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-12-2021, 12:03 PM   #6
Peanut74
I went through the same thing so I feel your pain. No engine/trans for weight so compressing the springs to get them in was scare. If I were to do it again I'd probably go the wood block route until the engine/Trans was in.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 01-12-2021, 12:32 PM   #7
69Tom
69Tom's Avatar
Thanks guys. Some good ideas here.
Old 01-12-2021, 02:01 PM   #8
BigBird05
I just detailed my frame. Use the wood block idea.
BigBird05 is offline   Reply With Quote
Old 01-12-2021, 02:10 PM   #9
ChevyRacefan
ChevyRacefan's Avatar
2) pieces of 2"x10"x1/4" plate.
3)1/2 threaded rod 2)10" long (cut from one piece) 1)6" long
6)thick washers
6)nuts.
1) rag if you are worried about scratching the spring.
step 1
drill holes in the plate for the threaded rod to go through, just outside the spring coil( both sides of spring)
step 2, drill holes in the plate so the 3rd rod is in the spring center , this is so if the tool slips on the coil it can't go anywhere.
step 2a
glue rag on plate that will contact the spring if scratching spring is an issue
Step 3
on threaded rod nut, washer, plate, plate ,washer, nut on the rods for the outer holes in plate.
step 4, Put on spring and put 3rd rod in the center hole with washers and nuts, like the outer 2 inside the center of the spring.
step5. screw the nuts down the threaded rod evenly on either side, and the center.
step 6
put spring in frame and a arm, connect ball joints, back off nuts on threaded rod.
simple, reusable , cheap, and it works .
note 3rd rod is for safety, nothing more.
ChevyRacefan is offline   Reply With Quote
Old 01-12-2021, 09:41 PM   #10
70STOVEBOLT
70STOVEBOLT's Avatar
I put my short block in and that was enough weight to install the springs. I had the rear wheels on the ground and the front on jack stands under the front crossmember. I put a jack under the lower control arm and put the spring into the pocket and jacked it up until I coulld out the nuts on the ball joints and torqued them down. 402 here also
DISCLAIMER: My truck came from the factory with a six, so my springs are the original six cylinder springs. I don't know if that makes a difference or not, but factory big block springs may be heavier. I will say, the front end did not drop much, if at all, with the big block.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-13-2021, 09:15 AM   #11
my67c20
I put a floor jack under the lower arm (with a block of wood), slide the spring into the pocket, put a large ratchet strap (chain might work) over the upper control arm and around the jack, then pumped up the jack to compress the spring. Worked like a charm.
my67c20 is offline   Reply With Quote
Old 01-13-2021, 01:07 PM   #12
71CHEVYSHORTBED402
That's a great idea. I can't speak for some trucks, but unless I'm missing something you can't use the threaded rod trick on my trucks because the top of the coil spring fits underneath the engine support & there are no holes on top.
Tony
Old 01-13-2021, 01:15 PM   #13
ChevyRacefan
Doesn't need one, the center rod is 8" long and the nut you turn is at the bottom, the top nut and washer just there to hold it together.
Like running a nut up a bolts thread.
Old 01-13-2021, 04:16 PM   #14
69Tom
69Tom's Avatar
That definitely might be worth a shot.
Old 01-14-2021, 06:11 PM   #15
SCOTI
SCOTI's Avatar
This. A 4x4 block of wood works just fine. Used them on my 67/68 in storage for years.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-15-2021, 01:19 AM   #16
71CHEVYSHORTBED402
I think I understand now, thank you.
Tony
