01-12-2021, 05:16 PM | #1 |
Prop Valve Leaking
I installed a CPP prop valve (PVKS-2) when I did a disc conversion 3 yrs ago. The valve is now leaking at the back but not at the line connection, it's leaking at a large nut that was already in place and never removed at install.
Anyone have any experience with this problem? Worth trying to get it to stop by tearing it down or just replace it? I ordered this through Summit and it's no longer available but their replacement is close to $100. Any other suggestions? Thanks.
'68 GMC 3/4 Ton 350, 700R4 |
01-12-2021, 05:22 PM | #2 |
Re: Prop Valve Leaking
Clean it off & try tightening as is. Watch to see if there is any improvement then go from there.
01-12-2021, 07:18 PM | #3 |
Tried that, it won't move at all, really tight already.
01-12-2021, 10:57 PM | #4 |
Sounds like its replacement time. Don't know that trying to rebuild is worth it.
01-12-2021, 11:26 PM | #5 |
Chevy guy
I bought mine direct from CPP and it leaked the same way. I called their tech support and they sent me a replacement. It takes a odd size wrench to remove and be sure to use a backup wrench on the block when you remove it.
Tehachapi, Ca 57 BBW shortbed 64 C30 service bed 65 C10 long bed fleetside 70 C10 long bed fleetside 74 C30 flatbed |
01-13-2021, 01:07 PM | #6 |
What is sealing the adapter? is it a flare type seal or a gasket type, on the idea of the gaskets on rubber brake hoses, to clappers?
01-18-2021, 12:14 AM | #7 |
BMW & ASE Master Certified
Its an o ring that seals that rear adapter to the body.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
01-18-2021, 02:08 PM | #8 |
I went with a Right Stuff prop valve, will be getting it installed before too long.
