Old 12-18-2003, 07:12 PM   #1
cojnit
Nothing clever
cojnit's Avatar
Cutting spings?
Can I do this with a cut off wheel?
If not what is the best way(s) to cut them?
Got "the Midas Touch!"
cojnit is offline   Reply With Quote
Old 12-18-2003, 08:45 PM   #2
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
I would think anything that can cut through the steel should work. I used a oxy-acteleyne (sp?) setup to torch mine a 1 1/2 coils shorter.
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 12-18-2003, 08:47 PM   #3
cojnit
Nothing clever
cojnit's Avatar
what about the heat warping the coils?
Old 12-18-2003, 09:39 PM   #4
70c10
67-72 Addict!
70c10's Avatar
A cutoff wheel will work good.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-18-2003, 10:52 PM   #5
PrimeredThunder
Back from the Dead
Well, since the coils are made of some serious steel I dont think you should have a problem with warping. We threw some intense heat on my stockers and they were fine. I just wouldn't sugest cutting more than 1.5 coils.
Salem, Oregon
Old 12-19-2003, 11:24 AM   #6
MOTHERTRUCKERS
Years ago before drop coils could be bought we put the coil in a 5 gallon bucket of water and had the part of it we wanted to remove sticking out of the water and torched it off, the coil would sink to the bottom and quenched itself.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 12-20-2003, 01:31 PM   #7
theo70
COMING SOON...
theo70's Avatar
I second the cutoff wheel...takes awhile, though.
theo70 is offline   Reply With Quote
Old 12-20-2003, 11:24 PM   #8
ShamrockCustoms
Project56 on hold
ShamrockCustoms's Avatar
put spring in good vise. use circular saw with "chop-saw" blade.....like butter
Shamrock Customs
Forever-in-the-Future Custom Shop
2009 Mitsubishi Lancer GTS daily driver
1956 Chevy Stepside rodstoration on winter hold
ShamrockCustoms is offline   Reply With Quote
Old 12-21-2003, 12:19 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
You might get a funny look when you go to the Hardware store and ask for a "chop-saw" blade for your 7" circular saw. It is actually a ceramic tile blade, and it will do the trick.
I have used just about every method you can think of and this one produces the least amount of heat on the spring.
Like MOTHERTRUCKERS said, if you use a torch, put the srping in a bucket of water. This keeps the rest of the spring cool.
Believe it or not, you can cut it with a hacksaw and a good blade. It takes a while, but it's not as bad as you might think. Don't ask me why I know this....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-21-2003, 06:50 PM   #10
ShamrockCustoms
Project56 on hold
thanks, could not remember the type of blade for nothing! im just gettin old. time for ginko biloba!
Shamrock Customs
