Old 12-18-2003, 07:48 PM   #1
Stout72
Not my good side.
Stout72's Avatar
Question Lift determination
Anybody know what the distance was between the center of the hubs and the top of the fender well arches, from and rear, on a stock '72 K20 Custom Camper? I'm trying to determine how much suspension lift my truck actually has. There's no body lift. Too many P.O.s and not enough info.
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress.
00 Suburban LT
90 Camaro RS
79 Yamaha XS1100 Special (Ol' Reliable)
Stout72 is offline   Reply With Quote
Old 12-19-2003, 12:04 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
My restoration pack for 1969 trucks should be pretty close, but no guarantees that dimensions stayed exactly the same, rather than try to explain the dimensions I will just post the pic for you to go by.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-19-2003, 12:08 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here's pic.
Old 12-19-2003, 12:29 PM   #4
Stout72
Not my good side.
Stout72's Avatar
Thanks, Yukon. I have the resto pack, too, but the dimensions there don't take into account tall tires. I was looking for a shortcut that takes tire size out of the equation. I guess I'll have to do some math. I suspect I have a 4" lift back aft because of the 4" spacer blocks under the rear leaf springs. I can't really tell what I've got up front. It could be 2", there are 2" extenders on the bump stops, but I have no idea what one of the POs was thinking. The truck does have a slight bit of rake to it. My hub center-to-fender arch distance measures 28" both front and rear.
00 Suburban LT
90 Camaro RS
Old 12-19-2003, 12:36 PM   #5
alf4444
alf4444's Avatar
I just bought a book called 69-81 Blazers. Haven't read it all the way through but I remeber seeing some measurements I think it was ground to bottom of front diff. if that helps let me know and I will look again.
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
Old 12-19-2003, 01:02 PM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
The rear pic has the ground to bottom of dif measurement so that should help you. Good luck.
Old 12-19-2003, 11:32 PM   #7
Chevy Punk
The distance between the hubs and the fenderwell will not change with different size tires
Chevy Punk is offline   Reply With Quote
Old 12-22-2003, 04:36 PM   #8
Stout72
Not my good side.
Stout72's Avatar
But that distance does change with a lift. That is my question. I'm going to be in the market for new shocks soon, and since I'll need 8 of them, I'd like to shop for the right ones, length and travel-wise, the first time. Would be good to know exactly how much lift my truck actually has. Since I have no history on what lift kit is in it (except for the Superlift sticker inside the glove box door), I have no idea what a PO installed.
00 Suburban LT
90 Camaro RS
Old 12-22-2003, 06:42 PM   #9
griesel72
griesel72's Avatar
i just measured mine, 71 K20, no lift and only 80000 miles, so springs should be in good shape. From the center of the back hub (i don't have the front fenders on yet) to the top arch of the back wheel well measures 23 1/4 inches.
Hope this is what you are looking for.
david
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 12-23-2003, 04:31 PM   #10
Stout72
Not my good side.
Stout72's Avatar
Thanks, David, that helps. Only 80K original mi on a 71? Wow! I should be so lucky. Let me know when you get the front fenders on.
00 Suburban LT
90 Camaro RS
Old 12-23-2003, 05:46 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Dunno if this will help you at all; just checked the fronts of my 72 K20 with 2 1/2" softride springs - 25 1/4" from hub center to wheel arch. Didn't check the rears because of add-a-leafs in the rear spring packs.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-24-2003, 01:28 PM   #12
Stout72
Not my good side.
Stout72's Avatar
Yeah, Stocker, that helps. I have 28" hub center-to-wheel arch, for both front and rear. Your front measurements tell me I have a 4" lift up front, not the 2" or 2 1/2" that I thought. Griesel72's rear measurements confirm my 4" lift in the back.
Thanks, guys.
00 Suburban LT
90 Camaro RS
