Proprietor of Dale's Corner
![]() Join Date: Nov 2012
outer bearing removal HO52
How do you remove the outer hub bearing once the clip inside the hub is removed?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Re: outer bearing removal HO52
You drive the brg. & race out the big end.
George |
Thanks George, so my instincts were correct. Destroy the bearing and seat in the process probably.
Should I use heat or take it to a machine shop and let them tackle it? What a stupid design....
All about them K’s
![]() Join Date: Jun 2014
Easy, jack up truck, remove HO52,, slide this under... bolt everything back up, enjoy!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Thanks, I took it out and installed a dana 60. A friend is wanting th ho52 for the locker....
I meant to include pics...
Maybe a couple more....
All about them K’s
Nice work! I’m sure that 60 will be a little easier to keep running, those HO’s are getting harder and harder to find parts for.
#10 | |
![]() Join Date: Dec 2009
If you know of a Machine Shop near you? They can turn a Step-shaft down to drive it out. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Thanks for the information. I think heat would help too. Thanks for the compliment.
