Old 01-15-2021, 06:39 PM   #1
osaltyone
osaltyone's Avatar
Coolant leak from oil pan
Got the truck up and running and have been trying to figure out my coolant issue. Thought I’d post here to see. I have a LM7 in my 49 3100. Swapped the oil pan with one that has a lower profile, but seems like I have a coolant leak in one of the spots that had a hole for a bolt but my block doesn’t have a bolt hole. Anyone run into this? When it’s @ 190 seems to just pour from there.
osaltyone is offline   Reply With Quote
Old 01-15-2021, 09:05 PM   #2
osaltyone
osaltyone's Avatar
Re: Coolant leak from oil pan
Think i found the issues. Coolant temp sensor is leaking I’ll swap it when engine is cool again. Odd that oil pan bolt is not there though.
Old 01-15-2021, 11:11 PM   #3
Captainfab
60-66 Nut
I would have drilled and tapped the block for that bolt.
Old 01-16-2021, 02:03 AM   #4
gmc684x4
Looks like the gasket is off center on that hole
gmc684x4 is offline   Reply With Quote
Old 01-16-2021, 06:47 PM   #5
LS short box
Be careful when you replace the temp sensor and don't over tighten as they will break quite easily. Ask me how I know.
LS short box is offline   Reply With Quote
Old 01-25-2021, 09:53 PM   #6
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
My LM7 is the same as yours. No bolt drilled / tapped there.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 01-25-2021, 10:29 PM   #7
osaltyone
osaltyone's Avatar
Good to hear it’s not just mine.
Coolant temp sensor was backed out for some reason. Maybe when I had the engine out and cleaned everything.
Old 01-26-2021, 09:41 PM   #8
derotoreut
derotoreut's Avatar
Glad to hear that's all it was. Got to love an easy fix.
~ Dan
