71 K10 Fuel Tank relocate
Good Morning,
In building my 71 K10 shortbed fleetside, i would like to install the fuel tank in the rear frame area using Tank's Inc 69 Camaro Fuel tank. I have searched the threads and found many threads i see that pertain to C10's not K10's as they all have trailing arms and springs vs. the leaf spring set up. I want the fuel filler to come out of behind the license plate area. Is there anyone out there that did this mod to their K10 that can share mounting ideas and pics to help me out? I am installing the original 350 turned into a 383 Stroker. (not pertinent but...) Thank you in advance. |
landarts
![]() Join Date: May 2005
Re: 71 K10 Fuel Tank relocate
What you are trying to do will work. C10 or 4x4 will not make a difference in the frame in the rear where you want to put it. I used the Mustang tank and 90 ohms fuel sending unit from tanks Inc. and it worked perfect. I went with this tank because it is low profile and can not be seen hanging down, also fits between frame rails. Camaro tank is also a great choice.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
#3 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Suburban blazer tanks fit well between the frame rail
Thank you everyone for the quick replies! I will call Rob @ No Limit thank you for that suggestion. Aslo, on the Mustang Tank from Tanks Inc, What year of Mustang tank did you get, and do you have any install pics where you did the straps, etc. Is it a rear fill so i dont have to deal with any fancy fuel filler? I just want to keep complicated down to a minimum.
Old member
Robs tank sits on the frame rails lip no straps. He does send bars though.
This was in my 68 step. I sold the truck before I finished it so I never got to try it out. Rob will help you with anything you need. I had him go ahead and do the fuel injection sending unit mount even though it was a carburetor just in case. No extra charge. I ended up not using the 2 extra bar straps. The frame rail held it nicly. ![]()
