Old 01-17-2021, 12:40 PM   #1
03BlkZ
Fuel line help!
Ok I have and issue. I am restoring my 70 C10 with my rebuilt 350. I have swapped to summit carb and I am trying to figure out how to run my fuel line from the pump to the carb. I seem to have misplaced my original but it had a Q Jet on it before so the line would be different. I want to try and not use any rubber and would like to put a filter in line somewhere between the pump and carb. Here is a pic. The heater hose fitting has since been changed out for a 90 degree allowing plenty of room for the fuel line.
03BlkZ is offline   Reply With Quote
Old 01-17-2021, 12:53 PM   #2
notsolo
notsolo's Avatar
Re: Fuel line help!
The 3/8 line out of the pump makes a sharp very hard to bend 110 degree, needed to clear the bottom radiator hose, then bends back and hugs the block vertical, and would meet up with what you have...photo from other member...but you get the idea
notsolo is offline   Reply With Quote
Old 01-17-2021, 01:07 PM   #3
notsolo
notsolo's Avatar
Re: Fuel line help!
This was a Quadrajet line.
Old 01-17-2021, 01:29 PM   #4
kenn
Re: Fuel line help!
Hello, It's been a while but I used AN fittings at my carb and pump with a filter just after the carb fitting and then cut the length of line between the filter and the pump fitting. I think I bought them from jeggs. Sorry I cant do pictures.
kenn is offline   Reply With Quote
Old 01-17-2021, 01:29 PM   #5
Grumpy old man
Grumpy old man's Avatar
Re: Fuel line help!
This might help .
http://67-72chevytrucks.com/vboard/s...d.php?t=791117
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 01-17-2021, 03:03 PM   #6
03BlkZ
Re: Fuel line help!
This might be my best option. Thanks!
Old 01-17-2021, 03:23 PM   #7
BigBird05
Re: Fuel line help!
You would be better off running a hard line from the pump to the carb and putting your filter in the rubber hose in front of the fuel pump.
BigBird05 is offline   Reply With Quote
Old 01-17-2021, 05:24 PM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Fuel line help!
I put a filter under the cab coming out of the tank and one up by the carburetor on my ramp truck to insure no trash ever gets to the filter inside the carburetor again. The bronze filter in the picture was right before all the new filters where put on, old gas poured into bucket out of tank then had it cleaned at the radiator shop before reinstalling it. Installed new rubber lines and bronze filter. I blew the hard line out good inside the frame rail. I caped the end off under the truck and sprayed it full of carburetor cleaner good filling it up. Caped that end off and let it sit for about 1 hr. Then blew it all out. I did this twice.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-17-2021, 05:40 PM   #9
MAC71Cheyenne
Re: Fuel line help!
If you don't have the goods a decent machine shop can bend a hard line with some measurements and couple pics. Grumpy has me hooked on painting the intake but it is going have to be a bit warmer and have some time to tear it all apart. Maybe after I grab a couple of lock doc's ram horns... Grumpy, you ain't endearing me to the wife!
MAC71Cheyenne is offline   Reply With Quote
