Born To Lose Club
![]() Join Date: Feb 2003
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
A Little Off Topic...
Brian Smith ![]() 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
That's the 1st one I have ever seen. I guess napco would have done the conversion?? Also the shackle's are mounted up front kinda wiered.. Killer looking truck though..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Firefighter
I think that someone turned it into a 4x4, it doesn't look like the frontend that NAPCO usually used it looks like a mid 70's style, matching the motor. Also look at the gear housing and the spring, it looks like the spring is setting on the housing, also look at the shock mount it kinda looks cobbled up on the axle.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Canadian694x4
In 1958 the Napco conversion would have been done at GM. Something about the front axle does not look correct to me. The tranfer case shifter does look correct. I always thought that this is a perfect combination to have but was unaware if the factory ever offered it. The crossmember for the transfer case would have had rivits instead of bolts to secure it to the frame starting sometime in the 1957 model year. A very nice truck for someone to restore.
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
![]() ![]() Join Date: Jul 2002
I thought the Cameo's were an integrated cab and bed. That looks to be a regualr Apace model. Have no idea though if they were 4x4 or not though.
Watch out for your cornhole !
![]() Join Date: Jun 2003
Bill, no Cameos were simply fibergalss bedsides installed on normal step side beds. They also used special bumpers and such. I've read that the bumpers on a Cameo project could make or break the deal much moreso than the condition of the bedsides.
Dana 44 front axle = NOT ORIGINAL. Like it has been said, the Napco front axle has a round diff cover and has "NAPCO" cast into it in fairly large lettering. ![]() Also, notice the tie rod up above the axle, not in front like the dana 44...and there is only one U-bolt on the diff side on the Napco...there are 2 studs there (a la dana 60) that hold where you think the other U-bolt would go, vs. 2 U-bolts on the dana 44. I believe I read somewhere that the Napco front axle is a modified Eaton HO unit, and it does resemble one. You could get the Napco Powr-Pak on any truck back then, so yes, you could have gotten an original Cameo conversion from Napco. However, I have only seen a couple of these trucks, and common sense would dictate that back then, 4wd would be put on utilitarian work trucks, not the fancy Cameo. But there are a handful that do exist. Try this website, they have a lot of good info and pictures of Napco trucks: www.napco4x4.org
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Born To Lose Club
I was pretty sure it was a PO conversion...thanks for the link 1969 GMC!!!
My son, my joy.
Did anyone else click expecting to see a Camaro on a 4x4 truck frame?
