01-17-2021, 10:05 PM | #1 |
Gauge cluster rewire
During my LS swap, I installed a 91 Suburban electronic speedo cluster. All was well except the plug area of the printed circuit board had terminals that were coming up and crossing circuits. I tried gluing them down in place but it was still crossing each time I would install the plug.
So today's job was to install a disconnect in the wiring harness. I found an unused 16 slot plug set from the LS harness. Added wires to get to the 14 I needed. Some of the colors did not match up, but now I do not have to unplug the cluster each time I pull it out. Check it out. All soldered, shrink wrapped and taped.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
01-18-2021, 12:02 AM | #2 |
Re: Gauge cluster rewire
I'm intending to do the same thing, but for a little different reason. I'll pin a battery hot and GMLAN wires into that plug, as well as the usual cluster wires. I'd like to play around a little with some other cluster options, particularly some DIY electronic options. If I install a common GT-150 connector like yours, I can easily swap clusters entirely without having to repin anything.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
01-20-2021, 09:53 AM | #3 |
That's a cool idea. This plug was under the Underhood fuse box on a 2003. I have swiped a couple to keep on hand. Once you learn how the terminals come out of the plugs, the possibilities are endless.
01-20-2021, 10:42 AM | #4 |
Here's a pic of the cluster about to be installed. Next time I remove it, no worries about the printed circuit plug.
01-20-2021, 11:32 AM | #5 |
chevy truck fan
Jay, very interesting cool idea... I may bug you more on... how the the plugs get re-wires...
