87 owners help needed on a bolt, thanks
Folks,
I recently pulled my 87 350 tbi. The oil pan had a bolt on the right side that also held a bracket to support some cooler lines. I set this bolt aside and I have misplaced it. I took a picture of the surrounding bolts and the head mark looks marked “LF” see picture. Could an 87 owner look at the bolt which holds that bracket to see if it is also marked “LF” so I will know that is specifically correct as I am looking online for a correct bolt to replace it. Also any idea where to get it so far no such luck online if the “LF” is correct. I’m on the picky side and would like to put back what came on it headmark etc.. Thanks so much 🇺🇸 Posted via Mobile Device |
#2 | |
#3 | |
Re: 87 owners help needed on a bolt, thanks
The bolt has a stud head. The bolt goes on first then a nut holds the bracket to the bolt.
If it helps the "LF" is a stamping for Lang Fasteners who manufactured the bolt. The 3 lines on the face mean it is a grade 5 bolt, and the head style is a "Hex Washer" style bolt.
1987 R10 Silverado - Rusty But trusty Daily 1984 C10 Custom Deluxe - Newest Project |
well oil pan bolt scrapyard. Depending on side pan it's the trans cooler lines bracket(right), or motor oil cooler bracket(left)
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
The bolt that holds the cooler line bracket has a stud on it's head like Sean said. Install it then the bracket with nut is secured to it.
#7 | |
Always impressed by your threads.
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
#8 | |
I'm goofing with an OBS truck right now. I'm getting old and don't really do into full builds much anymore except motorcycles. Just fun fix up projects that I can drive and enjoy as I work on them. It's getting so expensive nowadays and the parts are such crap quality it has dampened the fun on it all a bit to be honest.
#9 | |
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
#10 | |
| Bookmarks |
