Watch out for your cornhole !
![]() Join Date: Jun 2003
Hooker pictures!
Not that kind of Hooker, you perverts!
The kind the brown truck brings. Hooker Comps, Jet-Hot coated for my big block conversion saga.
Helper
Firefighter
Well I'm disappointed!!! Nice looking headers though!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Nice looking header's what's the funny bend for?? Look's like you got a good help great to star em young..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
![]() Join Date: Sep 2003
ooooooo,,,,aaaaaaahhhhhhh,,,
I can hear them singin' tubes already!
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
That funny bend cradles the starter. It's less than 3/8 inch from the starter.
Up till now, I've always been very happy with Hooker headers. We'll see.....wouldn't it be great if I had to buy one of those little mini starters after spending 3 hours re-building mine last night? (I'm being sarcastic, it wouls suck to have to buy a new starter).
I USED HOOKER 71 CHEVELLE HEADERS FOR MY BIG BLOCK....NO FUNKY BENDS
LIKE THE ONE'S U GOT THERE....I HAD THE SAME ONE'S...... AND YES I HAD TO BUY A MINI STARTER ![]() AND CUTE LITTLE HEPLER YOU GOT TX ![]() |
so...furious...can...barely....type.....
Summits getting these *****es back on a fast train! Yes, that's touching my freshly POR15 painted engine. By the way Nova Cobra, that's my daughter, not son.
Ragenrat- are you saying that you had a set like this, with the funny bend? I figured it was defective. Are all Hooker truck headers supposed to be shaped like this?
Could I please see a pic of your Chevelle units? I might have to buy some of them.
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 12-18-2003 at 11:57 PM. |
JunkyardJohn, these ARE 369 dollar Hooker Comps!
These ain't no 79 dollar cheapies.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#13 |
John, I'm very sorry if I offended you. I'm dealing with a bit of fury concerning these things. I installed the gasket and tightened them down, I have about 1/8 to 1/4 clearance between the pan and header now. Is that going to blister the paint on the pan?
This having to buy a mini-starter is disapointing for sure. Again, John, I'm sorry, I didn't mean to come across a a jerk.
#14 |
WELL HAVE'NT STARTED THIS RIG IN MONTH'S
![]() CAN'T REALLY GET A SHOT UNDER SIDE NOW DRIVERS SIDE TOP Last edited by rage'nrat638; 07-12-2007 at 07:09 AM. |
#15 |
PASS.TOP SIDE
#16 |
![]() NO PROBLEM. IF YOU USED GOOD HIGH HEAT ENGINE PAINT I DOUBT THAT IT WILL BLISTER YOUR PAINT. ![]() ![]() ![]() ![]()
#17 |
These are Headman ceramic. They are the only ones I found that fit a 4x4 4spd manual. I did have to torque the pass side to get it to clear the starter and front differential but I am with you on the money they cost 300+ delivered. They should have fit without any problems. In this world of old trucks I find that sometimes you have to give a little or sacrafice a little to have anything that is decent.
#18 |
Used Hedmans on my 502--2" tubes with 3"collectors. Fit like a glove . Did not have remove anything or raise motor to install from below (except sparkplugs). $215 for headers-$217 for Jet-Hot coating.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#19 |
P.S. -plenty of starter clearance.(had to add a high torque later because stock 402 starter was not up to the task--Powermaster mini)
#20 |
"Ochre Ogre"
Does it make me a pervert if I was hoping to see pictures of tow trucks?
and just in case you really did need to see some non-header or non-tow truck type hookers, TAKE A LOOK HERE. I gots me a PHD, pimpin hoes degree.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 Last edited by da-burb; 12-19-2003 at 01:57 AM. |
#21 | |
#22 |
THE QUICKER FIXERUPER
You won't have a problem with the paint melting I had a set of jethot coated dynomaxes and one of the plug wire boots was up against a tube and it never melted or discolored. They say the coating reduces the temp by 75%, I belive them.
#23 |
Low & Slow
Hey Tx Firefighter, Are you going to have any ground clearance issues with your exhaust since the truck is so low? I know the full lengths on my 350 hang to low right for my 4" drop. Maybe you have lower speed bumps around there? :p
70' C-10 LWB Fleetside 4.5/6 drop ![]() |
#24 |
Got big-block?
![]() Join Date: Jul 2000
Hey Kevin, I've got a pair of Hedman 3/4 length Chevelle headers for the 468 in Daisycutter. They seem to fit OK, but I've only held them in place...haven't bolted them down yet.
#25 |
You got hookers patented oil heater model. Ragen rat...isn't your headers super comps?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
