Old 12-18-2003, 11:31 PM   #1
krue
Designated A-hole!
krue's Avatar
My fingers are crossed
Maybe the rubber gasket I put on my tranny oil pan will stop the leak. I am losing about a quart of tranny fluid a week! I dropped the pan, cleaned everything up and tweaked the pan straight (I hope). Put a rubber gasket on and put it back on. Maybe it will seal this time.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-18-2003, 11:39 PM   #2
jorgensensc
jorgensensc's Avatar
Krue,
Your sure it's not the freont seal aren't you?? Mine is leaking about 2 tablespoons on the concrete overnight. I need to replace it, but DREAD taking the tranny out to getto it. I HATE WORKING ON THE TRANNY!!!! It seems no matter what you do, tranny fluid always gets everywhere!!!!!!
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 12-18-2003, 11:45 PM   #3
krue
Designated A-hole!
krue's Avatar
Took the tranny out and replaced front and rear seals. I could tell where it was coming from fairly well, I just couldn't get it to seal.
www.daveramsey.com
Old 12-19-2003, 01:57 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Hey krue, if the tin isn't straight enough to let the rubber gasket seal, maybe Santa will bring you a nice shiny new finned aluminum pan!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-19-2003, 10:10 AM   #5
Frankd
I had the problem of blowing pan gasket on mine found clogged vent - alowing pan to build pressurre
72 c-10
81 c-30
67 c-10 just sittin in the woods)
70 C-10 " " " "
to compleete frames 67, 70 - in woods
2002 toyota tundra.
12 yr old son has , 72 Charger, 78 Ramcharger and 85 ford wrecker
Frankd is offline   Reply With Quote
Old 12-19-2003, 11:46 AM   #6
Grim Reaper
I had the front Pump housing to case O-Ring fail on wone. It looked like a pan leak at the front. Changed that pan gasket twice.
I'm fighting with my 75 right now. 1-2 Shift acumulator cover is leaking. Put new seal in didn't help. I stacked two seals (they are O-ring style) and so far that seems to have worked.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 12-19-2003, 01:06 PM   #7
tom hand
CCRider
tom hand's Avatar
I have had this problem....seems that whatever some of the newer cork gaskets are made of, will allow the tranny fluid to leak through the gasket, even with no other problems. Mine only did it when the truck was parked on a hill. Where did you get the rubber gasket?
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 12-19-2003, 02:10 PM   #8
kevin's 4X4
kevin's 4X4's Avatar
our burb is doing the same thing ! leaking like a mother f-er ! I took it over to my moms and left it there for the winter ! I will get under it next summer to fix the problum ! Tranny work sucks !!!
FYI : Kevin's 4x4 is also know as landon4421 !
The boy wants an avatar !
kevin's 4X4 is offline   Reply With Quote
Old 12-19-2003, 04:32 PM   #9
krue
Designated A-hole!
krue's Avatar
Well it's still leaking! I guess I need to check everything else now.
I am pretty sure the vent tube's not clogged because I checked it before I reinstalled the tranny (in October).
Tom, I got the rubber gasket at O'reilly's. It's a Pioneer part. I can get the number off of the box if you want it.
www.daveramsey.com
Old 12-19-2003, 04:38 PM   #10
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
if your flange isnt straight ont he pan youll have to glue the gasket on or replace the pan
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-19-2003, 05:28 PM   #11
krue
Designated A-hole!
krue's Avatar
I have tried glue, a new pan will be next, after I make sure that it's not something else.
www.daveramsey.com
