01-22-2021, 11:48 AM | #1 |
Is a collapsible Steering Shaft necessary
Going to be installing a new aftermarket steering column. Been reading threads on the steering shaft being collapsible. But also read that it has 2 pins holding it together. So what is the point of it being collapsible if it can't slide without drilling out pins and hit it with a hammer? Thanks
01-22-2021, 12:07 PM | #2 |
Re: Is a collapsible Steering Shaft necessary
Safety , in 68 federal law mandated collapsible columns , side marker lights, no flip seats etc, etc , the collapsible column worked by shear force to snap the pins and prevent a direct shaft to your chest in an accident , The 67 shafts are one piece and people died from hitting the solid steering column shaft . 1960's technology .
the flip seats that weren't solid mounted would launch people thru the rubber gasket windshields , look at the cars that received these safety measures first in the 60's
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 01-22-2021 at 01:14 PM. |
01-22-2021, 12:11 PM | #3 |
As I restore my 67 I am trying to leave it original but some changes such as a collapsible column are available in tilt and nontilt and don't compromise the original look in these trucks. Imo it's necessary if you plan on driving it lots.
01-22-2021, 01:00 PM | #4 |
The 2 collapsible steering shafts that I have seen (72 C10 and 74 Challenger) had plastic melted into the through-holes to keep it together for assembly purposes, not pins. My friend push/pulled to hard while removing his column from his Challenger and sheared the plastic. Not a big deal as it was pretty tight anyways and after it was re-installed...it can't go anywhere and is still collapsible.
Now, my 67 F@rd has a one piece shaft and they call it "the harpoon". It's about 5 feet long and will get you on the chest if you have a bad head-on Collison.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
