Old 01-23-2021, 08:23 AM   #1
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Question Replacing Parking Break Assy
I have a new parking break assy and had its pedal pad move to the right so it can clear my new kicker speakers. I have a 72 C10 LWB 350/TH350 and hoping to get some advise on how to remove the old one and get the new one installed. The currently one is fully installed (with everything around it installed) and working properly.
Things I think I know:
1. Remove the two assembly's firewall nuts
2. Remove the underside assembly's nut/bolt on the dash.
3. Likely loosen (or remove?) 3 driver side dash bolts - to loosen the right side of the dash?
4. Push / slightly knock the Break Assy to the right to get it out.
But before all the above I am pretty sure I need to deal with the Brake Assy cable. I know there is a cotter pin/clevis pin attaching the parking brake line to the assembly but I assume this is under wee bit of pressure (even when the brake is not engaged). Do I just go underneath the truck, driver side, behind the transmission and loosen the adjustment nut to gain some slack?
I have read and found a few posts on removing the assembly, which is where I got my 1~4 "things I think I know". Though I haven't found how to best/properly do the parking break cable.
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 01-23-2021, 09:14 AM   #2
ChevyRacefan
ChevyRacefan's Avatar
Re: Replacing Parking Break Assy
Disconnect the front cable were it meets the rear two. You should be able to do this without touching the Adjuster. If you feel you need too.
ChevyRacefan is offline   Reply With Quote
Old 01-23-2021, 09:29 AM   #3
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Guess I am going to need to spy that underneath to see what you mean. That would be nice if I could do this without touching the adjuster.
Richard
Old 01-23-2021, 09:30 AM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Make sure the clevis pin is reinserted in the same direction. If it’s flipped 180 it’ll move slightly over time and get caught on the assembly when the pedal is depressed.
Old 01-23-2021, 09:34 AM   #5
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
So, you mean the way it is inserted into assembly and insuring the cotter pin is on the side it is on now? Good tip. Before I started removing stuff, I was going to snap a few photos of things (always good to have a reference on this were before mucking with it)!
Richard
Old 01-23-2021, 09:45 AM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Correct. Keep the cotter pin on the same side it is now.
Old 01-23-2021, 10:01 AM   #7
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Arrow Re: Replacing Parking Break Assy
For the record I did look at the Service Manual but it really makes it seem easy. I mean even with the parking brake released, the cable must be on a bit of tension (meaning I'll not be able to get it back on). Then they say unbolt it and remove it, nothing about loosening the driver's side of the dash.
Then the only way I can see how to loosen the cable, is at the adjuster. Unless removing a brace would also give the cable a bit of some slack??
Richard
Old 01-23-2021, 11:37 AM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Replacing Parking Break Assy
You may want to check this thread out I did a while back.
http://67-72chevytrucks.com/vboard/s....php?p=7608320
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-23-2021, 11:53 AM   #9
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Andy, I think I saw that a bit ago, I assume you mean wiring up a a switch to engage the dash's "brake" light? That is a clever idea and seems rather easy.
Might you have any insight when you took yours out of the dash? I would appreciate any/all tips/steps/problem areas?
Richard
Old 01-23-2021, 02:15 PM   #10
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Well, much to do about nothing, it seems... It was easy to pull out, zero problems. I barely touched it to the right (to the passenger side) and it started to move out.
When I got ready to put in the clevis pin, I did have to loosen the adjustment. What I actually did was first removed the driver's line from the C-Clappy thing that goes to the driver's rear wheel. I figured it's got to be easier to manhandle down there, than up around the clevis pin!
So, uninstalled, reinstalled, and the parking brake still works. Yay me!
Oh and my parking brake pedal now clears the kicker speaker - which was the whole point of this!
Shout out to Leon (LockDoc) for selling me this parking brake assy for a great price and for my brother (who cannot see this, because he cannot figure out the internet) for moving the pedal and painting it black!
Not bad for Leon shipping it to my bro on the 14th, my bother doing the work on the on 18th and me installing it today on the 23th! Then all you guys listening to me whinging here this morning - it was a fine team effort LOL
Richard
Old 01-23-2021, 02:41 PM   #11
Andy4639
Old member
Andy4639's Avatar
Sorry I posted and left for a cruise in. Just got back. Looks like it was no problem. Mine came out easy enough I figured yours would to. Glad you gotter done.
Old 01-23-2021, 05:02 PM   #12
LockDoc
The Older Generation
LockDoc's Avatar
Good deal Richard. I knew you could do it....
LockDoc
Leon
