![]() Join Date: Aug 2020
And here we are, new signal switch in a '71 tilt column.. Nope!
Easy peasy day of installing the real truck wheel and found out signal switch was junk. Basically came apart.
Have a new switch so no problem, nope. Because of the junker I just cut the wire from the half moon plug n pulled everything out. Going to wire the new and the half moon connector doesn't fit unto the wire run for the tilt. The first column cover is off but can't figure the tapered shift lever cover removal. Column is in a neutral position. All levers are removed. The only other way I see is to pull the pins in the half moon but trying a dozen different approaches I've struck out with that too. Lots of search time reveals noting specific other than try this... I would prefer not to but would disconnecting the column shift mechanism to the transmission on the engine side of the firewall allow the 'bucket' to slide down the column a bit to make room for the half moon? Tilt lever is in the pics trying different angles. Last edited by MAC71Cheyenne; 01-23-2021 at 11:49 PM. |
Re: And here we are, new signal switch in a '71 tilt column.. Nope!
Problem solved. Came up with a resolution that may help everyone else down the road. See the new post for the solution.
Mr. Cheyenne
![]() ![]() Join Date: Jun 2020
I'd be interested in where you sourced your tilt signal switch with cable. Many thanks!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
I got this one from Classic Industries. They show the two different hazard switch styles, button and the red hazard. Went with the red. Mine had been replaced before with an unknown and was a lighter construction than the one I got. Complete junk...
The GM units would be nice but at $100+!? This one was like 50 and a solid unit. Tilt, PN 1997961 |
Mr. Cheyenne
Thank you for that!
I just also had a thought, now that I see what to search for - GMCPauls has one too. 67-72 Turn Signal Switch With Tilt 132884-2 or 19717013 1967-72 Turn signal switch for TILT steering columns. 100% correct just like original, with red hazard knob and correct curved steering column to wire harness connector. Made in the USA $50.00 I know mine is incorrect because the hazard on this one is "black" ![]()
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 01-25-2021 at 10:59 AM. |
GMCPauls is my first choice for vendor. Thought I would share a bit this time. What he shows looks like the same item. As Arnold would say, do it.
Mr. Cheyenne
So that bowl, how did you get that off?
I was able to get the old signal out pretty easily (like I saw on a You Tube), since the hazard could come off (black pull). I have my new signal wires down the shaft but the new signal Red Hazard pull doesn't come off and I cannot get it down into the bowl. I do have a tilt from a fellow named Randy here on the forms (I have no idea if it is a real C10 Column) . I have the tilt lever off but i can't figure out how the bowl comes loose/out - feeling really stupid.
Mr. Cheyenne
Looks like I need a reverse puller to get the upper cover/bowl - do I have that right?
How do you re-install it?? http://67-72chevytrucks.com/vboard/s...d.php?t=447180
The shroud can be a stinker...sometimes they just pop off if you can get a long small head flat screwdriver down in there to release one side then twist a bit and pull. I had to use a wheel puller with the two hook tabs on the inside rolled edge to pop it loose. A gentle tap on a block across the face should reseat it.
Don't feel bad about all this. It took a bit of cussing and staring at it to figure it out. That's why everyone is here to help. M |
Mr. Cheyenne
I have three different pullers, none allow me to reverse :'( So looks like I'll be getting on from O'Riley's up the street. At least I don't need to buy it.
So, when this Shroud/Cover/Bowl comes off, no other parts under this thing will fly out? Thanks - guess I'll make dinner before I am skinned by the girls.
Mr. Cheyenne
none of the pullers from O'Riley's or Auto Zone were of any help. But Andy4639 ended up helping me by suggesting a small screwdriver inside the tilt shaft hole and tapping the bowl up. Then I switched to the hazard side and did the same. Back and forth, tap, tap tap. Then it came out little by little!
I guess I'll hop back to my thread that started me down the road of replacing the signaler.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 02-05-2021 at 01:01 AM. |
Glad you made it work. That was going to be my next try if I hadn't gotten lucky. I have the puller kit from O'Reilly's. It wasn't the greatest for this. Had to get it assembled at a funky angle and I got lucky enough for it to loosen up enough I could pop it loose. If someone did this often enough, filing or grinding the hook tabs thinner would allow it to grab much better.
#13 |
Mr. Cheyenne
thanks for all your help Mac and letting me camp in your thread :-)
#14 | |
Old member
![]() Quote:
Glad you got sir. These old trucks can be a pain in the a$$ some times but worth it in the end! ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#15 |
Thumbs up...any time!
#16 |
Mr. Cheyenne
Funny thing, I was just adjusting my antenna and my neighbor came out to leave for work. He said, damn you work on your truck more than I do with all my cars (he as like 3 cars they work on).
I told him, she just need her antenna straighten. Can't have her be driving down the road with a crooked antenna! He about feel over laughing :-D Though he knows I was working on it all afternoon into the night on the signaler (I had asked him about a puller when he *came home from work*! But I have not regretted working on the truck with my various "projects". While I have gotten frustrated from time to time, at the end I step back and smile and think, gee that was a bit of fun LOL
#17 |
The good news is it is not 12 degrees in your neighborhood, yet...
#18 |
Mr. Cheyenne
12 degrees in Kyle (south of Austin) - just don't happen! I was actually sweating yesterday after noon as it got to the mid/upper 70s LOL
