01-23-2021, 10:33 PM | #1 |
All about them K’s
71/72 throttle cable
Anyone bought a reproduction cable assembly recently? The cable in my K20 bit the dust today, they just don’t make things to way they used to I only got 49 years from it
Just wondering if I can trust aftermarket quality and fit or if I should look for an OE cable.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
01-24-2021, 11:23 AM | #2 |
Old member
Re: 71/72 throttle cable
It's been a few years but I bought the Lokar cable stuff. It works great. I have also went to Lowes and bought the 1/4" cable and locks and and made a throttle cable before. I used the old sleeve housing.
01-24-2021, 11:27 AM | #3 |
Carpe manana
I don’t have an answer but GMC Paul fwiw does carry a cable for 4wd applications. OEM pieces seem scarce these days.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
01-24-2021, 11:45 AM | #4 |
All about them K’s
Thanks guys, it was the cable sheath that broke, the cable itself is fine. I’ll check our GMCPauls here in a bit. I need a few other small parts anyway.
01-25-2021, 09:32 AM | #5 |
All about them K’s
Just an update, neither GMC Paul’s or Classic Heartbeat carry the 71/72 cables, I ended up ordering from Classic Parts, I’ll update on the results when it comes in.
01-25-2021, 11:33 AM | #6 |
Old member
Here is the thread on mine when I did the Lokar pedal install. It's a direct replacement for a stock pedal. They have them in black also.
http://67-72chevytrucks.com/vboard/s...d.php?t=722763
01-26-2021, 03:16 AM | #7 |
When you remove the old one, If you could, ship it off, I would like to see if I can reskin it. I have done this to other vehicles that parts are next to impossble to find.
