01-25-2021, 11:11 PM | #1 |
Catalytic Converters?
Have any of you added catalytic converters to your Blazer to reduce exhaust odor when you're running without the top? I'm thinking about it and wondering how well it worked for you. I have 2.5" dual exhaust exiting behind the rear wheels and my carb and timing are properly adjusted.
Thanks.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
01-26-2021, 08:50 PM | #2 |
Re: Catalytic Converters?
What engine are you using? You can't just put catalytic converters on and expect them to last especially with a carb. They need oxygen to work either by the use of an air pump or one way valves that suck air into the exhaust.
The best thing you could do is get rid of the antiquated carbureted engine and install something late model. At the very least, get rid of the carb and get fuel injection. |
